Topping L30 Headphone Amplifier Review
@JohnYang1997 Been reading through this thread and have decided to get an E30+L30 stack. Will the red/blue options be ready/shipped to suppliers for the 11.11 sales? I'd be happy with black but it'd be super cool to get a colored option
Calm down boy, I'm dibs on blue and red :p
John said in this topic that they should be ready "end of october / beginning of november". I'm hoping for them every day that goes by.
PS : nice Scrubs reference ;)
Pulled the trigger on the E30+L30 ensemble from Apos. Currently on its way across the pond. Excited to get this setup!
I just measured the channel imbalance of my L30 with a 1 kHz sine wave at low gain:
9:00 volume position: -0.37db
10:00 volume position: -0.37db
11:00 volume position: -0.18db
12:00 volume position: -0.02db
13:30 volume position: +0.20db
15:00 volume position: +0.13db
@JohnYang1997 is that within specification?
Edit: I just noticed there is a small range just above 09:00 where the imbalance is around -0.7db.
It's fine, within 0.5dB. Refer to Wolf's sample also.
Emmm? 0.7dB. That's not good.
I ordered mine from shenzhen audio on 15.07.2020, I guess it must have been from an early batch before you changed the pot matching process. Should I send it in for exchange?
There is no early batch. If you found it to be an issue then yeah get a replacement.
It explains why I thought that some headphones had a slight balance issue when using medium gain at around 09:00-10:00. @JohnYang1997 Should I send it to Topping or Shenzhen Audio?
@JohnYang1997: I consider to purchase 2 L30's as double mono preamps (to active speakers) for the benefit of far better channel separation (crosstalk-reduction) and increased power stability for the cost of a bit of a clumsy volume control (what doesn't bother me). Therefore I plan to install one L30 for only left channel connection and the second one should handle just the right one. Each unused inputs and outputs will be closed with a MegOhm resistor to avoid possible noise or interference for whatever reason. Also my headphones (Meze 99 classic) should be handled that way- easily done with it's separate L/R jacks (after tuned Left&Right Cables).
Do you see the chance of significantly better performance doing that way?
Greetingz, Robert
Greetingz, Robert
no
Greetingz, Robert
If your active speakers have bal inputs you could use L30 is a mono bal pre-amp (each bal signal go to a channel of L30 eg.: positive go to left channel and negative to right channel), but I don't see any significant quality gain on it. If you already have got them, give it a try...?
Hello!
How much Current can the L30 output at each gain setting when paired with E30?
Thanks
