o7_brother
And how no one talked about it when A90 came out?![]()
Because that one has XLR inputs as well... wait, do those require the standard 4Vrms from the DAC or is it some higher number?
A90 can do XLR in XLR out, so with double input voltage and balanced output it will obviously go a lot louder than L30... it doesn't need >4Vrms...Because that one has XLR inputs as well... wait, do those require the standard 4Vrms from the DAC or is it some higher number?
And better gain switch. And actual availability in Europe (pending).The real reason to buy this over a magni/atom gonna be availability or that sexy output switch
I can't even max out mid gain with dt880 600Ohm....most rambling "audiophiles" I've seen listen at like 120db (judging from their power requirements and gear), they're most likely deaf or on the way![]()
But RCA input? Anyway. I get it.The A90 was tested with XLR in, 4Vrms. It measured 2W @33ohm, Unbal out, matching the spec sheet.
Quick (hopefully correct maths) and a90 spec sheet would need 3Vrms input for the balanced output to get full power, ~18Vrms although higher distortion threshold than 0.1% will probably yield more power (in turn need higher input voltage). It's gain is 15.5dB or about x6 for the balanced output.Because that one has XLR inputs as well... wait, do those require the standard 4Vrms from the DAC or is it some higher number?
Ok guys. That's cool. Next amp: +18dB gain we go.
Good channel balance, absolutely no noise with most sensitive iems, actually usable with IEMs, -9dB gain setting, DC protection, DC blocking input.The real reason to buy this over a magni/atom gonna be availability or that sexy output switch
With A90, I never need high gain even with 600Ohm DT880. In fact I just bought Audio Technica R70x for its 400Ohm and sound tuning. Because my other headphone is Oppo PM1 (64Ohm).Ok guys. That's cool. Next amp: +18dB gain we go.
Well i prefer L30 any day but the specs are confusing. This is as powerful as Atom then. Heresy more powerful.How many you guys listen to headphones with high gain volume maxed?![]()
Will it bother you if I only put it in High gain? Just asking for some suggestions. Personally I only use mid gain or -9dB gain.Not for me, I love my A90, and with XLR in, I doubt I would ever even need high gain, as I make all my headphones balanced.
There will be the true THX 789 killer.Well i prefer L30 any day but the specs are confusing. This is as powerful as Atom then. Heresy more powerful.
I will criticize Topping product management though. There are too much products and prices all over the place. A90 could've been THX 789 killer but it's priced premium. Dac amp combos have ridiculous output impedances.
Yep strong points of THX 789. Good to see on cheaper product. Schiit high gain is ridiculous. But i don't understand the relation between gain and power. Can't you have more power but same gains ? My SBX AE5 is louder than SE THX 789 but THX have 4x more power.Those are not necessarily practical issues. Gain settings are. It would affect user experience if you have too much gain, unusable high gain setting.
Even in terms of performance, noise performance definitely matters for sensitive IEMs. This is one of the few amps that actually usable for sensitive IEMs. Low noise essentially made the high SINAD number.
In the end I'm not at all saying this amp is just better because it has better performance.
But at this rate of competition you need to have higher performance.
Y though. SP200 wasn't that great with its super high gain. meh. people be deaf, I guess.Ok guys. That's cool. Next amp: +18dB gain we go.
Honestly this is better than all.The real reason to buy this over a magni/atom gonna be availability or that sexy output switch
