Topping L30 Headphone Amplifier Review
3125b
Germany
You must have weird RCA cables then. Mine (Cordial) fit equally well and tight on E30 (1911 batch) and JDS Atom.
half_dog
Brazil
You must have weird RCA cables then. Mine (Cordial) fit equally well and tight on E30 and JDS Atom.
Eeer... I use the same cables on a Atom and Khadas Tone Board (former setup) and the fitting is quite tight.
jadenphan
Hi all, I just got my L30 to pair with my E30... I just used it for like an hour, and I seriously need help. I am not sure if anyone experiencing what I am right now, but here is what I am experiencing:
1. The L30 got really hot, like not warm, but HOT.
2. Plugging in my DT990 headphone in and the noise started to crackle nonstop at all settings (seems to be better on -9db) and on any streaming platforms or PC/laptops. OMG!
I am not sure if this is a defective unit, or if I am doing something wrong. I sold my lovely Atom Amp to get this to pair with my E30, and I am questioning this decision now. Could you help me? (P.S I am using: RCA JDS Labs Stack Cable 15cm/0.5ft)
Thank you so much!
half_dog
Brazil
Does the power supply have the correct voltage? If yes, did you try L30 with another DAC or player (use Y cable and connect your pc/mobile/laptop)? Try to disconnect L30 from any device and listen to it if there is any noise turning the volume pot and differents gain setting.
solderdude
The Neitherlands
Thank you so much!
As half_dog already mentioned: Check if the power supply has the correct mains input voltage.
When this is the case:
When nothing is connected but mains and the headphone do you hear crackling or noise ?
Does the power supply also get unusually warm ?
jadenphan
I am in US, so I believe the voltage is correct? 100-120V input. Unfortunately I don't have another DAC to try this with, I will try connecting the Y cable directly to my phone/laptop later to see. But currently via E30 and 2 different laptop devices, the same issue is present.
half_dog
Brazil
I believe so, although you can get 220V from outlets on US. Would you have another system (active speakers, receivers, amplifiers...) which has RCA inputs? Would be interesting to test E30 as well. As I said before, either the E30 and L30 I've got have don't have a nice fitting with my cables and when they get loose it makes some noise. If possible, try different cables.
jadenphan
I just swapped out a different 1/4 inch headphone adapter, and it seems to help with the crackling. Interesting... I will keep an eye out for any other crackling.
Regarding temperature, probably there's not much to do about it? I am just afraid under long uses, it will incur some damages with excessive heat.
half_dog
Brazil
Huuum... Nice! Well my experience with this amp and Atom showed that they will get hot driving low impedance. May I ask which version of DT990 you have?
jadenphan
I have the 250 ohm version, so not too low of an impedance. I mean, it just seems kinda hot even when in standby mode or preamp mode. But maybe that's normal for this model?
solderdude
The Neitherlands
With the DT990 at normal listening levels just a few mW will dissipated so should not raise the temp significantly.
Temperature increase could come from 2 halves of the TPA6120 having different DC output voltages or idle current from 2x TPA6120A.
Since some complain about temperatures (often without actually measuring) my bet would be one of the TPA6120 may have different DC offset at their outputs In such a case the 2 output halves will be connected via 6.6 Ohm and a voltage difference would mean it would draw a constant DC current while the combined output would have little to no DC.
I expect John knows if this could be a cause of raised temperature or not. No idea what the spread/tolerances are in a nested feedback situation.
110V is the correct voltage for US.
Crackling can indeed be an adapter, dirty plug or brand new socket causing this.
jadenphan
Thank you for your insights. I think the crackling was indeed caused by my adapter as when I changed to a different one, the crackling is gone. However, I am not sure if the brand new socket has anything to do with this as well? I question this because I was using the very same adapter with my Atom Amp, and the issue wasn't present like with the L30. Should I be worried about the L30? Or is this a sole/exclusive issue from the 1/4' adapter, and the Atom Amp just acted differently (meaning not as harsh and producing crackling like L30).
Regarding temperature, since I am a newbie in the audiophile field, my knowledge is very limited. I didn't officially measure the temp, I was just telling the high thermal based on current uses, and comparison with my past uses of Atom. I'm curious if the high thermal is something concerning or if it is still in a tolerable range.
solderdude
The Neitherlands
Not all 6.3mm sockets are created equal. Some of them make better contact or at another spot on the ring or tip. Also not all 6.3mm plugs are created equal. Some tips have deeper 'dents' then others.
Some very new sockets in amps may have some cleaning agents on the contacts that wears off after inserting plugs a couple of times.
Just switch the amp off. Let it cool down and when you switch it on check how fast it gets warmer.
Or just put a thermometer on top. everyone has one. Takes the guessing out.
Just above body temp metal is easily felt as very warm/hot.
At 60 degrees you cannot hold your hand on it after a short moment.
jadenphan
Ahh, that makes lots of sense!! Sockets vs plugs...
Thank you for the suggestion. I will measure this time to see how quick and how hot it gets. Is there a benchmark I can base off of to see whether the temp is within the tolerance?
solderdude
The Neitherlands
I would think a 10 degrees celsius increase over a time period of a few hours could be normal for a small metal enclosure with no venting openings.
aHaidc
Okay, there is one thing that's annoying and it isn't L30 (serial 2005) exclusive - same on E30 (serial 2003). The RCAs connectors have a smaller diameter than usual making almost all my cables being kind a loose cutting the signal. There is another E30 (serial 2006) here and the fitting is okay, did Topping realize this and replaced the connectors?
Same issue on my E30
solderdude
The Neitherlands
The problem with metal surfaces is that when one touches it and the temp is below that of the fingers heat is drawn from the fingers making it feel colder than if you were to touch plastic.
When you touch a metal surface that is higher in temp it quickly conducts warmth to your fingers where plastics don't so a metal surface feels hotter.
So for this reason measurements are better than touch.
The notion of what a 'warm room' is may differ regionally so is no 'measure'.
We need to know the baseline temp, the on temp after an hour or so and when stacked this will also greatly affect the final temperature.
