from zero to 9what position is the volume knob of your L30 in when listening at the low volume setting? Like 12 o'clock, 9, etc.
I think i see your point
If i use the amp outside that zone no issue You are right
thanks a lot I think i will get one thenThen with the L30II you will most likely have less channel imbalance, because you have to turn the knob up more to get the same volume, so you're more in that optimal zone.
Did you buy it second hand? There has been a recall and exchange program for all serial numbers smaller than 2012xxx. Take a look at the older posts: https://www.audiosciencereview.com/...-headphone-amplifier-review.15226/post-630733Thank you, I managed to open, here is the information.
So far it has worked very well so I haven't worried about any technical variations of the product in its existence.
Happend to mine. Disconnect and destroy I would say. Definitely don't plug headphones in again. Or anything to the rca for that matterYes unfortunately I got this one second hand, it broke down after I touched it and got a static shock, I inquired about the serial numbers in the meantime and it seems that static electricity is a problem, in any case the circuits have no apparent damage, but hey I think I'll find a more solid replacement, my electronic knowledge is poor........
So you got scammed. Did you buy on ebay? I would report the person, since he/she got a replacement for free from topping and was supposed to destroy and throw away the old device. Maybe it‘s even illegal to resell a device that has been recalled, but I‘m no legal expert.Yes unfortunately I got this one second hand
Someone knowingly sold you an early/faulty unit while he got a replacement for free. Sad indeed. Hopefully karma bites him in the end.It's very sad, I got it on a famous French second-hand site, my Sennheiser HD 560S still works after testing, it's the one that was plugged into it, I was afraid for him, Topping D10S and Aiyima D08 still work too.
Objection your honor. Speculation.Someone knowingly sold you an early/faulty unit while he got a replacement for free
Fair enough but it's likely. The bad originals should have been marked or destroyed.Objection your honor. Speculation.
