I know it, but in those mentioned cases none of them there is earth ground causing the current leakage.Grounding is not needed for 2012 and later.
The enclosure normally gets its ground via the gear connected to it.
I thought on this solution but I was afraid it could cause a short circuit somehow. And for these situations ("floating sources") maybe groundloop won't be a problem because the only gear connected to safety ground would the amplifier... I will try it and report back, but not now - it's 3:40 am here =PIf you want ground just connect safety ground to the enclosure or the RCA shield using a piece of wire (which may introduce a groundloop)
Thanks one more time @solderdude
BTW, I'm not 100% but it seems A90 adopts this solution. The GND from HP output seems to be connected straight to safety ground.
