EHC
I just completed (it was in a long queue !) adding my own ESD fix to the "retired" early batch unit I was left with after the Amazon seller replaced my L30 last year. Very simple; just dremeled away the paint inside the inner case where the volume pot nut screws down, added a solder lug and washer to the pot shaft, soldered a short wire between it and the ground point via beside the rear RCA and screwed everything back together tightly. Measured and now seeing dead short between RCA shields and the aluminum case or pot shaft.
Works perfectly...absolutely no difference between sound of this one and my "factory fixed" unit with the pogo. 20 mins of work and 2 X L30's for the price of one......I won't ever sell the DIY fixed unit of course, but I'm quite happy to run my HD650's off it in my home office....it will be totally fine now.
I think your headphones are still at risk. In my humble opinion, ESD vulnerability is just a consequence. The fundamental cause is OPA1612 noninverting input "in the air" when an imperfect contact at the potentiometer cursor occur. The cure is a simple resistor between OPA noninverting input and ground (two, actually, one per channel, 22k-100k). The replacements come with modified protections to, wich is nice.
