solderdude
This is now fixed with an added resistor so no longer an issue.
I thought it was used to compensate DC offset on signal path. Sorry for the confusion caused.The NE5532 is not in the audio path.
It just works as a level detector.
It is completely irrelevant what the used quality is as long as it functions as it should.
It can provide 26.6Vpp = 9.4V which in 300 Ohm =290mW
The 250mW would be calculated from 50 Ohm load = 8.6V at the knee of distortion but without the 50 Ohm will be somewhat higher.
Former is a pretty old design that might play well with high impedance headphones like HD6xx etc. L30 is lower output impedance lower distortion and much lower noise, plays well with a lot more earphones/headphones and IEMs. Buying a WHAMMY is buying old-generation amplification basically, might not be bad depending on your needs. But hard to compete with current stuff like L30 or something like Drop 789, etc...Just wondered if anyone had measured/compared the WHAMMY headphone amp against the Topping L30 HPA ?
Hmm I thought it was a fair bit older but okay, 5 years ago, sounds about rightThanks Very, actually I do have higher impedance headphones , or medium high ( 250 ohms ) so your observation was of interest to me. I do have a couple of low impedance headphones also but don't use them much, or for for serious listening.
I wasn't the WHAMMY was considered very old since it debuted back in 2017, is it considered old technology in 2021 when compared to the JDS labs Atom or Topping L30 ?
I had the very thought to post my experience as I had extensively listened to music through my original 2005 serial unit and now have had plenty of time with my replacement 2012 serial L30.Even if it was replaced, new revision still sounds the same...
The 1ET400will reach 425W in 4ohm when it receives 9.4V on its input.
As it is single ended the pre-amp needs to drive 2kohm which is not a problem.
To reach the 1ET400 clipping level the L30 needs to be in +9dB setting and your DAC needs to have at least 3.4V output voltage 0dBFS.
Max U uit is 9.2V acc. to spec sheet (26Vpp) but it does not say at which distortion level.
Yes you have the ESD fixSorry for returning on the topic of 2012xxxxx. After I've read a lot of thread pages on this subject, I think that I understand the 90%-10% situation of 2012 version. I just bought mine from a Romanian retailer (avmall.ro). In order to check if I am one of the lucky 90%, I've removed the side screws and loosen the screws above RCA plugs. I attach the pictures. I kindly ask somebody who knows (since I am a noob) that my unit has that ESD protection (I think is the one I circled in the picture).
