WolfX-700
China
Noise is only 0.25uV.
I can confirm that it is less than 0.4uv-Less than Apx555B's NoiseFloor
In such a measurement, it will be very sensitive to environmental interference, etc.-I will confirm it again after I move to my garage
JohnYang1997
China
I just measured it right before the post. I had the volume all the way down and no input connected. When I had the input connected it turns into around 0.3uV but not stable reading. It's indeed lower than 0.4uV nonetheless.
You haven't mentioned the noise measurements method yet. I think I need shorter cables as well.
WolfX-700
China
You know, I am very conservative. I can see 0.3X or even 0.2Xuv-in some cases. But I think the stable measurement value I can conservatively say is less than 0.4uv.
I also need to customize the short cable-lol
JohnYang1997
China
Without input cables it doesn't go over 0.26uV.
iamwhoiam
It's not me that don't want to give permission first of all. It's complying to the whole plan.
Then the unit is really close to the final unit. Only a couple of cosmetic detail differences(not overall appearance or design) and that's it. Same power supply will be used, same board except for the LED for indication will be used, same power outputs, same performance.
As Wolf has said it, 33Ohm(32ohm) power is 2.2W(2.3W) both channel driven. It goes to 2.4W with single channel driven. 16ohm power is 2.8W both channel driven and 3.9W single channel driven. Ok I let it out. (All power numbers are with distortion less than 0.001%)
More to come.
Will it be AC or DC supply? If DC, then perhaps there is scope to improve with even lower noise etc.
(Probably not required though given the baseline performance!!)
odyo
Yuno
I'm not a big fan of (what seems like) reflective front panel, but I guess it is made this way to fit in with E30. Looks good otherwise.
Migel83
It looks not bad.I prefer to see a balanced output as suppliment.I think it was not possible to made of the Budget.
