Topping KB22 Audio Interface and Keyboard Review
Rate this audio interface+keyboard:
    Votes: 1 0.9%
    Votes: 5 4.3%
    Votes: 14 12.0%
    Votes: 97 82.9%
Mainly to declutter your desk by merging three devices together: keyboard, DAC and ADC. You also save on USB ports you need. It probably saves some money too over buying separates.
Podcaster / streamers, SM influencers, "prosumer music" producers, anyone whose computer is the center of their media life.
Dual USB interface, on its own pretty special, route I/O via PC + smartphone simultaneously
More than just 2-in/2-out for music mixing, inputs for multiple mics, instruments & line level devices, 6 loopback channels DAW routing, 10-band PEQ other built in DSP effects,
High res listening, 2x separate monitoring headphones
Dedicated gamer features mode.
Super clean specs a bonus!
And happens to be built into a keyboard.
Personally, I'd sit it on a nice big platform that slides or swings under the desk, all the cabling secured / well stabilised.
Maybe sit-stand, or easily swap over to a zero-gravity recline, for when relaxing with a Big Knob at hand.
If you only spend a few hours a day at a desk with keyboard in reach, I think this is not for you.
With a big knob at hand, I hope it's wipe clean
What an exhibition of performance for the price.
I get the high quality of the keyboard and the convenience for certain users. In my case, though, I need a wireless one, and to have a keypad too. So the keyboard part of this gadget is something I would skip.
But the audio interface part is impressive.
As a wish for these reviews, I´d love to see round trip latency numbers. For people that play guitar through plugins, low RTL is a must... and it´s pretty simple to measure with RTL Utility.
Great wrok as usual Amirm! Thanks for the review!
A lot of people use an external keyboard and a DAC or audio interface in their computer system. This removes one box, with excellent performance. I fail to see why so many fail to see the use case for this device :) .
Oh, no... I don´t fail to see that... on the contrary, I perfectly understand its use case. It just doesn´t match mine. In my home studio I have a "big" DAW/Mixer controller and a wireless keyboard. The front area of my desktop is free of cables. Audio cables go to a rack in one side... so my keyboard must be wireless for this reason... this keeps it as clean as posible and improves my workflow.
Besides, plugins and DAWs require a lot of numerical tweaks (at least in my case), so a keypad is also a must.
That´s why I need a wireless complete keyboard.
But that´s just me. I perfectly see a lot of people finding this concept useful.
The Qingning switches are dirt-cheap switches I've seen sold on AliExpress. Like 30 switches in a bag for 5-ish dollars cheap lol. The other switch Topping offers, I've never heard of. I'll pry keep some on hand or change them out. I also ran the listed Qingning switch specs thru my unhinged local AI bot on my pc to find other options w/ the same specs. She then told me Qingning's Tactile Switches are basically exact matches of the Cherry MX2A Tactile switches. I'll list the other ones she found below. 2 of them are full-length travel (4.0mm) & the other 2 are near matches to Qingning switches.
- Kailh Midnight Pro Tactile Switches- 5pin, Silent tactile, Operating Force 40gf, Total Travel 3.7mm, Actuation Travel 2.0mm
- Wingtree x Lichicx Orange Silent Light Tactile Switches - 5-pin+ Same as above specs, but 0.1mm Less Total Travel (3.6mm)
- KTT ZenCha Silent 40g Tactile Switches - 5-pin, Exact specs as Kailh/Wingtreebut has full length (4.0mm) travel.
- Cherry MX Brown Switches - 5-pin, 45gf Operating Force, Full-length travel (4.0mm), 2mm Pre-Travel, "Gentle Tactile Bump w/o
Click"
I suspect the Qinging is just Outemu Lime V3 rebranded, I actually own these type of switch and it's quite nice, tactile and very silent.
, I could not reach the stated spec of 24 dBu with the ADC clipping at slightly above 2.2 volt.
It usually happens to you when testing interfaces: you use the XLR input instead of the TRS for ADC tests. On interfaces, these inputs are typically for microphone use only—and that's the case in this device too. These inputs can't handle such strong signals, plus they have a preamp circuit that isn't used for line inputs(TRS).
With all respect, do you ever read the instructions before running the tests?
Edit: I wrote that from memory, and I've checked and it only happened with the Focusrite 2i2 4th Gen, from what I've been able to verify.Could it be that you had INST enabled?
And here i was in the market for a new keyboard, so a keyboard with a pretty much perfect interface/dac/adc inside it???
Sign me the f*** up!
Will definitely be buying this one in the future!
Here, I could not reach the stated spec of 24 dBu with the ADC clipping at slightly above 2.2 volt. Perhaps I have some setting wrong. Regardless, we land at nearly top of the class here:
Probably because you measured the different input.
The maximum input level for the TRS line in is 24 dBu. The XLR microphone in accepts 8.6 dBu, which is close to the 2.2 V RMS you measured.
EDIT:Ah, I didn't reloaded page. Seems like someone else already commented on this.
Couldn´t agree more.
Actually, it´s quite tempting even for me, just to put it in my rack, don´t even use the keyboard and just enjoy such a great performing interface.
Yes, this is a great product. Wish it had a number pad. I has a * key on the number pad that you need to change the viewing perspective in the game, Neverwinter Nights 1.
Latency according to Google
By utilizing the direct hardware monitoring path via the TOPPING KB Control Center, analog inputs (microphone or instrument) are routed directly to the headphone amplifier before hitting the computer's USB buffer. This completely eliminates perceived delay while tracking vocals or instruments.
• ASIO Driver RTL: When routing audio through a host system (such as DAW processing or a digital crossover engine like CamillaDSP), the true round-trip latency depends tightly on your buffer and sample rate configuration:
• At 48kHz / 64 samples, the driver achieves an efficient low-latency environment (typically sitting in the ~4.5ms to 5.5ms total RTL range).
• At 48kHz / 128 samples, the RTL scales comfortably to approximately ~7.5ms to 8.5ms, keeping it well below the standard 10ms threshold required for real-time interaction without noticeable lag.
• Onboard DSP Processing: Engaging the built-in Parametric EQ (PEQ), compression, or noise reduction happens natively on the interface's internal audio processor. This architectural design keeps latency fixed and prevents additional CPU buffering overhead on your host operating system.
So here's a thought...
1. You can plug more than one keyboard into a PC at the same time (I have 2 connected most of the time)
2. The KB22 runs the QMK firmware and each key on the KB22 is fully programable using the VIA interface.
3. Every key on the KB22 could be programmed to control a DAW function or another piece of software.
4. Keycaps can be replaced with custom designs or have dymo tape stuck to them.
So maybe the killer use of the KB22 is not as a primary keyboard, but as a highly customized secondary keyboard with a built-in Interface?
Thank you for the review, @amirm,
And custom keycaps are widely available for cheap, anywhere?
It used to be that the gamers loved their Cherry-MX keyboard keys... they still may. Since IBM keyboard days, I am a big fan of keyboards with mechanical keys, yet I have never had a single key that failed, even with my heavy usages (their 'actuation rating' is @100Million keystrokes). Although I have a ziploc full of new/worn/broken keycaps, as spares.
My current keyboard is the Corsair K70Pro, which I had gladly paid ~$150 for (w/Cherry-MX Blue keys). Amazon charges $140 for a set of Cherry-MX 120 key/switches (w/o keycaps).
The audio performance of this Topping KB22 keyboard appears to have exceeded the performance of their Topping E2x2 Audio Interface. kudos!
I love the concept but not sure I could get on with 4+ cables running a couple of feet back from my keyboard to the edge of the desk, although with a pull-out keyboard shelf or a large monitor shelf it would probably be fine.
I would definitiely buy a battery powered version that had a touchpad on the side. I realise it's niche but with a PC in my living room I currently use a logitech K400+ and then a Qudelix 5k for headphone use at night. Combining that in one high quality device like this would be awesome.
Usually keyboards stay in one place, so wireless is mostly cosmetic and dealing with a charging wire every couple of months is worth it. But if you add power-hungry devices like audio interfaces, you would end up charging most days anyway.
FiiO had one with only a headphone DAC/amp, no interface (KB3, still available on some shops). It is wired, but only a single cable. So might be worth checking out.
On a happy ending note:
Perhaps the next 'portable' iteration will add WiFi and rechargeable battery power... so that you can take it with you and use the keyboard for messaging on the go! :cool:
