Topping KB22 Audio Interface and Keyboard Review
Rate this audio interface+keyboard:
    Votes: 1 0.9%
    Votes: 5 4.3%
    Votes: 14 12.0%
    Votes: 97 82.9%
This is a review and detailed measurements of the Topping KB22 professional audio interface (ADC/DAC), headphone amplifier and keyboard. It was sent to me by the company and costs US $269.
Topping Professional KB22 Keyboard Audio Interface DAC ADC headphone amplifier review.jpg
Yes, this is an audio interface stuffed into a keyboard! I expected the keyboard to be cheap but the unit feels very substantial. The metal case gives it incredible heft, sharply increasing its chances of staying put once you dangle your cables from it. I am not into keyboard but this comes in two variations with different switch mechanism, replaceable switches, key mapping, etc. Sadly for me at least, it lacks direct playback controls (pause, play, skip, etc.). They are available as shifted function keys and such which make them not useful as I can by then use the mouse. Would have been great if on the top unused area we had such keys.
A very visible, though small, display lets you configure the modes and many operational aspects of the interface. You can however do that from its PC software. Audio interfaces can be overwhelming to use as just a DAC. Topping deals with this with a mode switch which highly simplifies the UI if you put it in "audiophile mode." Another mode for gaming exists which I could not figure out.
Software support inside the app is extensive and I am not qualified to characterize it. Suffice it to say, it seems to have a ton of effects/processing. Importantly we have parametric EQ.
Connectivity is nice with such features as OTG and USB hub:
Topping Professional KB22 Keyboard Audio Interface DAC ADC headphone amplifier usb-c back pane...jpg
On one side you have a power switch and on the other, 3.5mm and 1/4 headphone jacks.
I tested the unit with USB data and power over one cable. At first, I had a heck of a time getting more than 2 volts output of it. Then I realized the volume setting in Windows was defaulting to 67 every time I started a new test (opened the device). Same was happening on the input. This is through WASAPI interface. Maybe works better through ASIO, I don't. Either way, this shouldn't be happening. Sample rate was also limited to just 44.1 kHz in WASAPI. KB22 app has a drop down for other sample rates but the device itself needs to expose all rates. I am communicating with Topping on what is going on here.
I am going to run a subset of my tests since I can't run above 44.1 kHz anyway. Even if that was not the case, I would have had to triple the ticket prices given how much functionality there is here.
Topping KB22 DAC Measurements
Using our standard dashboard, we see DAC performance that finishes at the top of the class for an audio interface:
Distortion is extremely low and below threshold of hearing at -120 dB.
Dynamic range is superb for any DAC let alone an audio interface
We are talking 20+ bits here!
IMD test shows a hint of "ESS IMD Hump" in one channel:
It is a minor thing and as noted, this is excellent results for an interface.
Filter out of band attenuation is superb for a DAC:
Topping Professional KB22 Keyboard Audio Interface DAC Filter Measurement.png
Resulting in this excellent wideband THD+N response:
Topping Professional KB22 Keyboard Audio Interface DAC THD vs Frequency Measurement.png
Yes, there is a slight rise at low frequencies but still, this is really, really good result.
Topping KB22 ADC Measurements
Let's start with our dashboard here as well:
Here, I could not reach the stated spec of 24 dBu with the ADC clipping at slightly above 2.2 volt. Perhaps I have some setting wrong. Regardless, we land at nearly top of the class here:
Dynamic range is once again excellent for a DAC:
Topping Professional KB22 Keyboard Audio Interface ADC dynamic range Measurement.png
Computed EIN is a hair better than the spec at 150 ohm input loading.
IMD sweep delivers startlingly good results:
Albeit, level limited as noted.
Wideband noise+distortion is beyond excellent:
Topping Professional KB22 Keyboard Audio Interface ADC distortion and noise vs frequency Measu...png
Topping KB22 Headphone Amplifier Measurements
Budget audio interfaces tend to have dismal headphone outputs. Let's see how Topping does:
Topping Professional KB22 Keyboard Audio Interface Headphone Power 300 Measurement.png
Topping Professional KB22 Keyboard Audio Interface Headphone Power 32 Measurement.png
We have ample amount of power together with very low noise and distortion! You can drive all but the most demanding headphones with ease.
Combination of audio interface and keyboard may be odd but saves a lot of desk space. At the retail price of KB22, you expect a cheap keyboard, audio interface, or both. You get the exact opposite: KB22 embarrasses most ADC and DACs in audio interfaces. While I am not qualified to review the keyboard, it is seems to run should to shoulder with premium specialty/gaming keyboards.
Topping is clearly flexing its DAC muscles in audio interface world now. Its competitors better start to take them seriously. Very seriously!
I am happy to recommend the Topping KB22 keyboard and audio interface. It is a category busting device!
Interesting idea, less desk clutter (will require several cables though).
For Europe I see a problem: there are too many different keyboard layouts.
And, more generally, if the keyboard part fails, the whole device is "done".
I suppose that the steep rise of "content creators" has opened a whole new bag of needs, so something like that is maybe not the worst idea?
Really nice performance, both DAC and ADC.
At the keyboard part, it would personally last a week or so at my vandal hands (I'm not the typical desk user, there are times I take keyboards on my lap, specially when measuring around :p )
(are keyboards so small these days? Even if I exclude the numerical pad and a bunch of keys (the ones Amir would like) the ones I usual have is double the size? Is that the norm now?)
Thanks Amir!
This aligns with recent trends showing significant advancements in available, affordable ADCs—such as those from MiniDSP—in terms of their measured performance
. These represent new milestones... and should help shape the future development of many pro-audio brands, particularly as they adopt new ADC chips (like those from ESS, etc.).
WHAT
This is absolutely perfect. I've joked around I want my interface be integrated in my peripherals, be it display or keyboard. But them mad lads of Topping actually did it. And the performance is miles ahead of.. well, mostly everything?
Tenkeyless (TKL) keyboards are very popular. They give a more ergonomic position of your shoulders as you do not have to keep the left hand on the keyboard and the mouse as far apart.
It also makes more space for a large mousepad which is nice if you play games requiring a lot of mouse movement.
I guess you're right, If I had a single desk that would be the way.
But habits die hard, and I use a three "floor" desk with the keyboard at the bottom deck which is movable back and forth and the mousepad at the second "floor" (whick can go sideways also) for complete freedom (not a gamer obviously, it would be weird this way)
Reactions: EJ3
Oh noes, I was about to order but either I am missing something or there is not a Scandinavian (well, Finnish) keyboard layout available. If anyone at Topping is seeing this, please fix.
I may be wrong and I am certainly not a keyboard nerd, but isn’t it that with that type of keyboard switches keycaps are easily swappable?
What part you mean? They have swappable keys:
That`s a higher technical level than I expected (if the switches are available when needed, and the layouts are programmable).
(then there’s the issue of cables and the bulkiness of having cables connected directly to the keyboard... if it were connected to—and controlled by—an external hardware module, that would make a lot more sense...
just "remote"...
This could be done I guess. However, a correct layout out of the box is my very strong personal preference. Strong enough to be a deal breaker. I'd have to buy new key caps too, can't just move stuff around.
I don't need one but i kinda wish i did, thats a good product they have invented. if it had mac keys and number pad i'd get one quick
built in room correction please on top of the PEQ
