Topping E70 volume control issue with iOS
Circle
Hi all,
I recently got a Topping E70 to upgrade my old EX5.
I found when I have my iPhone (or iPad) connected to E70, I can still control the volume on the phone.
But when I connect to EX5 or the DACs I used before, the volume control on the system will be locked and can't be adjusted.
I wonder if this is a bug on E70?
MaxwellsEq
Is this a UAC1 vs UAC2 issue?
staticV3
If your iPhone or iPad continues to have volume control when it's plugged into a DAC via USB, then that means that the DAC supports UAC2 Hardware Volume control.
If you plug in a DAC and the volume buttons on the side of your iPhone/iPad stop working, then the DAC does not support UAC2 Hardware Volume.
Afaik, there is no way of disabling volume control on the iPhone/iPad in case the DAC supports that.
Circle
Circle
Oh, I see.
So, does that mean the volume I controlled on the phone is not the phone's volume but actually the DAC's volume?
