I thought this is to select the 4 or 5 volt output levels.Hi I hear the topping E70 velvet is set as default as measurement mode. Why is that? Is the measurement mode better than the sound quality mode?
L”: Measurement mode
“H”: Sound quality mode
What about ACL? Should have been replacedthe warranty was 12 months
Ah, well that's good anyway.luckily for me it still works well apart from the (bypassed) bluetooth
I can understand that.but my faith was low in the veracity of their guarantees
bwahahaha ! australian consumer laws are almost as bad as our privacy onesWhat about ACL? Should have been replacedor repairedIMO... sometimes quite a hassle though.![]()
and it's so old school to consider consumer goods should last beyond a yearyes, but our time is coming to an endWe must be old school then.![]()
and in the 80’s!I know this is ASR, but the hobby is kind of dead if we don't talk about sound. When I was visiting shops in the 2000s, all we could do is subjectively evaluate.
My WiiM Mini and CA CXC v2 sound great using the RAW-MDA1. It has worked flawlessly since new.
There are many fine choices for DAC’s with equally good performance. Are you set on this device?Hello guys, is it still worth buying the Topping E70 Velvet? It's currently on offer for €349. Or has anyone found a better alternative at a similar price or a cheaper option recently?
It is audibly transparent - so will sound the same as any well measuring DAC. At $350 it seems pretty good value for a balanced DAC with XLR interconnect.Hello guys, is it still worth buying the Topping E70 Velvet? It's currently on offer for €349. Or has anyone found a better alternative at a similar price or a cheaper option recently?
I wish there were more like you. There is too much subjectivism still in this forum. I think because something is branded velvet some may think and have some bias it's going to sound silky or smooth or something. Just look at the reviews and see the measurements, is it well designed and accurate, does it measure well and there's your answer. You'll prob even get something for less if your not too fussy about looks or features.It is audibly transparent - so will sound the same as any well measuring DAC. At $350 it seems pretty good value for a balanced DAC with XLR interconnect.
Although the SMSL DO300 is equally transparent, has more IO and is probably available at a similar price.
