Westsounds
- Joined
- Jan 10, 2020
- Messages
- 642
- Likes
- 454
The velvet name suggests it'll sound smooth and silky. So suggestive bias creeps in before you hear it.
Usually more self noise/hiss on tweeters and even some subs. I never had issues on 2-pin connectors where 3-pin almost always has some issues with self noise.View attachment 474240Hello, do you mean 3pin like this? Isn't a 3-pin interface more universal? What are the benefits of 2 pins?
So the difference after break-in was greater than the difference of adding new hardware?Mine arrived yesterday. Had to read the manual twice to sort getting into PreAmp mode.
First 30 minutes was not impressed. Let it play for several hours.
The sound had blossomed. Tails on piano notes are longer. Sound is glorious. Hooked the RAW- MDA1 back up. Played some, then back to Velvet.
Putting on teflon coated asbestos lab coat. Turds and flame protection.
Can easily hear a difference on certain tracks. The end of notes is more gradual. May be distortion. But sounds pleasing.
BUT, having the Auto On Off and triggers alone is worth the price of admission.
I don't quite understand that either.Does buying the E70 velvet and L70 stack make sense anymore with Fiio's K15 and K17 releasing?
In terms of the AKM type dacs. The K15 has two 4497svd and the k17 has two 4499EXs, the K15 is about the same price of the E70+L70 combo where I live and does pretty much the same in 1 package; I was wondering if that is the case is there any reason to buy topping's stack over the K15 or k17. The 4497svd seems to be very similar to 4499EX soundwise according to reviews.I don't quite understand that either.
There are plenty of examples where even 30-year-old devices have equally good or better measurements than current devices.
What would make the purchase no longer worthwhile for you?
The L70 has significantly more power than both FiiOs; only you can decide whether you need that, or whether the FiiO K19 might even be a viable alternative.
Just look at the measurements from the AP for all the devices; that should clear things up, because newer devices aren't necessarily better, even if the difference is probably inaudible.
And only you can decide on the features either.
The 31-band parametric EQ in the K17 is great, of course, if you use it.
It's no secret that the L70 has twice the power of the K17. But if you don't need the extra power, it offers no added value.In terms of the AKM type dacs. The K15 has two 4497svd and the k17 has two 4499EXs, the K15 is about the same price of the E70+L70 combo where I live and does pretty much the same in 1 package; I was wondering if that is the case is there any reason to buy topping's stack over the K15 or k17. The 4497svd seems to be very similar to 4499EX soundwise according to reviews.
This was kinda the answer I was hopping for: "The L70 has significantly more power than both FiiOs".
Does having dual 4497svd or 4499EX make any sound difference compared to the single 4499Ex the velvet has? or is it just for marketing purposes?
I need a DAC with XLR outs to the D1 would be off my list. I want to try the an AKM DAC since i have been using a SABRE DAC for quite sometime now. Well since the K15 has basically the same features, functionality and I don't really need the power should I choose the K15 in that case?It's no secret that the L70 has twice the power of the K17. But if you don't need the extra power, it offers no added value.
You wouldn't even hear a difference compared to an ES9039Q2M or AK4493, as long as all the DAC chips are well-integrated, because that's the more important factor.
You could also save money with a combination of the L70 and the SMSL D1 DAC. I've been using the D1 in my desktop setup for months now, and sometimes the SU-1 or PO100AK, even though I have plenty of DACs here that are 5, 10, 20, or even 30 times more expensive and are from the last few months/years.
My work equipment is a Gustav A18, which is now 5 years old, and the DAC in my living room HiFi system is now over 30 years old.
I would focus more on features, functionality, and the power you actually need.
You're expecting an answer here that only you can give.I need a DAC with XLR outs to the D1 would be off my list. I want to try the an AKM DAC since i have been using a SABRE DAC for quite sometime now. Well since the K15 has basically the same features, functionality and I don't really need the power should I choose the K15 in that case?
Just wait until you reach the 600 hour mark, the heavens will part and a ray of sunshine will illuminate the E70.
Just use a powerful laser; the "illuminating" will then be much faster....This is disappointing, it only took 550 hours with my old D90 (first series, no MQA) before the heavens parted and a ray of sunshine illuminated it...
