bumblebee657
- Joined
- Apr 12, 2024
- Messages
- 60
- Likes
- 119
I think the built quality of the E70v is excellent and I would expect the E70 to be the same.I had using E70 for a little bit it was new enclosure built quality is bad for the price and it makes some annoying noises when working or browsing in silence even three times cheaper audio interfaces has way better build quality. I was very disappointed by quality and send it back to amazon. The value for the money is tremendously bad it also uses that stupid 3pin ac input instead of two pin what probably is the main issue.
For three times less money for example Audient ID4 MKII or Universal Audio Volt 1 has way better build quality.I think the built quality of the E70v is excellent and I would expect the E70 to be the same.
On the E70, the voltage setting affects the analog output voltage of the Line outs.Maybe a noob question, but the voltage setting, what actually does this affect?
Received my E70 v today. The only way I could get DSD to play was by using KORG Audiogate 4.6 player. I own the KORG DAC 10R for recording to DSD and Audiogate will install when KORG DAC USB connection is verified (after 1 time verification Audiogate will run without KORG DAC connected).Tried it in DAC mode and also in preamplifier mode and the DSD filters still don't work, i.e. I don't see them appearing on the Topping E70 Velvet display
DSD are 1 bit and 2822400 Hz
Tried:
DSD64
DSD128
DSD256
DSD512
IN THIS CASE I AM NOT TALKING ABOUT HEARING THE DIFFERENCES IN LISTENING, I JUST WANT TO KNOW IF THIS FUNCTION ON THIS TOPPING WORKS OR NOT? BECAUSE IF IT DOESN'T WORK IT MEANS THAT THE DAC IS DEFECTIVE
well of course. That always happens when I buy just about any audio equipment!The Velvet model seems to have dropped -$100 recently (everywhere).
I remember it costing $449 and that being a bit over what I wanted to paywell of course. That always happens when I buy just about any audio equipment!
