Topping E70 Stereo DAC Review
Rate this DAC:
    Votes: 8 1.9%
    Votes: 8 1.9%
    Votes: 48 11.5%
    Votes: 355 84.7%
With usb-c you have more options (to lightning and so on) Higher durability? Is that true?
It depends what sort of durability you mean. Type C connectors are usually rated for more insertion cycles than Type B, and despite the smaller contact area they are rated for higher power (more voltage and more current.) On the other hand Type C usually has less physically robust mounting to the board so is more likely to be damaged by the plug being knocked or pulled. To mitigate this Neutrik made the mediaCON chassis mount.
This is a review and detailed measurements of the Topping E70 stereo USB DAC with Bluetooth. It was sent to me by the company and costs US $349.
I really like the new white multi-segment display with its large volume level indicator. Response is excellent as you rotate the encoder. A select button on the left turns on the unit and then selects the input in sequence. Or you can use the included remote control:
Nice to see 12 volt trigger being a standard feature on new Topping products, allowing you to turn on one unit and have it turn on the others like amplifiers automatically.
The output can be programmed to be nominal 4 volts (default) or 5 volts. I focused on testing the former.
Edit: forgot to mention that you have independent control over the outputs. You can have either RCA or XLR active or both.
I had a minor compatibility issue with USB input defaulting to 16 bits instead of 24 bit as far as Windows is concerned. I was able to easily override this using Topping ASIO driver. I wonder if this is something to do with my system or a new thing with this DAC. Operation was otherwise flawless.
EDIT: above is fixed with a firmware update: https://www.tpdz.net/newsinfo/778017.html
Topping E70 Measurements
Let's start with our usual balanced output measurement:
I expect superb performance from Topping and that is exactly what we have, landing the E70 near the very top of the best DACs ever tested:
Distortion is incredibly low at -145 dB or so. SINAD as a result is dominated by the noise of the DAC combined with my analyzer:
Even using RCA outs we get full audible transparency:
I have modified my THD+N vs output level to show broader range:
As noted though, as you reduce output, the analyzer noise becomes more dominant as well so above is not a true picture of the DAC's performance.
Multitone performance is superb as expected:
Likewise for IMD distortion:
Linearity is perfect of course:
Jitter is now nicely handled across both older S/PDIF and new USB interfaces:
As usual you have a menu of DAC reconstruction filters but I suggest staying with default filter 3:
The excellent attenuation of the filter translates into great wide-band distortion+noise measurement vs frequency:
The E70 is another meticulously engineered DAC from Topping at a reasonable price. The bright and large display is great to read from far, making the DAC just as suitable for general 2-channel system as well as desktop. Nice add-ons such as trigger support, auto on/off, etc. complete the picture of a DAC approaching and essentially achieving perfection.
It is my pleasure to add Topping E70 DAC to my recommended list.
I Think there is a AKM Velvet version of this dac. The one tested is with Sabre dac I Think
V1.07 firmware
I don't know what content has been updated, but the PLL bandwidth function of version 1.04 has been retained.
6. What's updated​
Fix some known issues. o_O
hmmm... any more details before i potentially brick the device ? :rolleyes:
any of the members able to elaborate ?
could it possibly resurrect the bluetooth connectivity that went to god ??
Hi,I use the E70 Ess Chip since more than 2 years now with the 1.07 version. It’s running absolutely flawless in every day uses in pre amp mode.This version has an added menu to adjust the pll bandwith for some TV or other devices with higher jitter.
For more information please read the first page's of this thread. The velvet has the AKM chip and an other SW so be careful.
might be language, but the 1.07 is dated aug 1, 2025 on their site, and the actual file is dates feb 22, 2025
so how exactly have you used it for >2 years, or have you recently updated?
fwiw i just discovered i am running 1.03 and it sounds fine via optical and usb
The
The 1.07 was offered here in the forum more than 2 years ago!!!! From Topping but not officially listed in their website. I didn’t know its now official. I didn’t check their website after updating with the unofficial one. (Never change a working system)
thanks for the clarification; your idea to never change a working system has merit, i will let working dacs lie until further info provokes me to change
6. What's updated​
I would give the give the 1.07 a try because of the Bluetooth. You are now 2 versions behind.
Sorry to hear that. The PLL was mostly for LG TV because of the horrible jitter.
all good
i have recently "tuned" my chain, and now that i have the sub phased correctly, and the crossover at 55hz for the wharfedale 10.gx (paired with 10.1), my discovery is that
bluetooth (even at 660 using ldac) is unfortunately no longer quite lovely enough when plan b is to use the recently made lossless spotify via the home theatre pc, and the phone that was streaming flac via bt (compressed due to that path) is now a simple remote for controlling the better reproduction
so overall that's a major win here :cool:
Hello! The USB port on my E70 stopped working. The USB cable I'm using is working properly; I tried connecting it to my other E70. I also tried connecting it to two laptops and a phone via USB, but it still doesn't work. Can you recommend something?
using coaxial or optical, because from my experience the e70 is treated as a disposable item by the manufacturer
but they sure do sound good when they work :)
My first E70 had Bluetooth issues out of the box—it didn't work. My second E70 only worked for a short time, and the USB input failed.
Because I have been using the E70 primarily for its USB and SPDIF inputs and XLR outs to tge L70, I hadn’t noticed before that the E70’s Bluetooth is advertised as transmission. Since purchasing the Sennheiser HDB 630 Bt headphones I believe I would like to enjoy a similar convenience from the E70.
However, if I put both into pairing nothing happens. I’ve browsed similar posts here without seeing a remedy… did I miss something?, like a FW update, or having done something stupid (… which, at 76yo, happens more and more frequently…)
The Bluetooth on the DAC is to receive incoming audio from another source, not to transmit to external devices as a source.
they are both looking for input, not talking to each other
site for the phones says "Get high resolution sound with included BTD 700 Bluetooth® USB C Dongle" so why not plug that in to a reasonable source (lke a computer / laptop / mobile) and you're good to go - at least as much as bt is "good"
the dac that handles that is in your sennheisers, so you are at the limitation of whatever bt you can use; again per their blurb :
Bluetooth 5.2 - Codec support is aptX™ Adaptive™, aptX™ HD, aptX™, AAC, SBC
no ldac? so sad, too bad - aptX is pretty good, but wired connection is so much better it's no contest if you have uncompressed source
you are limited by their applied technology with aptX as the available pinnacle unless there's a firmware update
bt = increased convenience at the expense of decreased fidelity- does it matter? that's a personal thing
