Topping E70 Stereo DAC Review
Rate this DAC:
    Votes: 8 1.9%
    Votes: 8 1.9%
    Votes: 48 11.4%
    Votes: 356 84.8%
ah, you europeans live in a different world...
don't i wish that was so
How so?
We have import tariffs from forever and the general guideline is to turn sanity into law.
(though we do have crazy stuff too)
What's more sane than to hold people accountable for what they sell?
Engineering is not only the nice numbers, is safety and conformity to the standards most of all.
So...
UK retailer, see servicing and warranty.
European retail/service at Audiophonics.
Order direct from China with discount or buy from your local retailer, the choice is yours.
thanks all for your comments, but i bought from the local distributor, and out of warranty they offer no repair
so as i clearly implied, europeans clearly have better protection for consumers, but in australia the rule of "get fucked" applies far too normally for most service, where 1 year warranty seems the standard (even for my spouse's spanking new pixel 9 pro at over twice the price of the e70)
at least the climate here is nice, and we don't live near potential for ww3
hardly cheap, and a year for electronics is the epitome of enshittification
encouraging disposable consumption is an outrageous waste of resources - which is one of the reasons my pixel 4a remains in service, perfectly functional and running android 15 (using lineage o.s.) rather than binning it because google support "finished"
the problem is huge, and getting worse
i don't mind that it is out of warranty, but i resent that fixing it makes replacement seem a reasonable alternative
I got today the Dac, and it's absolutely fantastic, the only thing i noticed it's that if I use it as preamp the soundstage sounds wider
a brief update :
shenzen engaged for a brief while, but any further action was denied once they eventually grokked i had bought the e70 from my local source, even though i explained the dilemma and noted that it was ultimately from their supply
their best offer was to ask topping to follow up, and i have been ghosted (insert high quality uncompressed cricket sounds)
so my advice is caveat emptor, though i have no knowledge that any other source of supply in my country of any product is any more reliable wrt services
interestingly, guangzhou offer 2 year warranty if you buy direct... more fool me for thinking it was safer to go local (as the product would have failed within their warranty, and the shenzen contact seemed very keen to fix the problem if it had been theirs)
not sure what the take home message is here, and thankfully apart from inconvenience with bluetooth out, the device is still a great dac for listening
well, time moves on and after shenzen referred my issue to topping i have been waiting for godot, but no longer !
unable to resist a bargain, and brave enough to trust a different chinese provider (or maybe just the same using a different brand name), i ordered this device, which has no bling at all, but replaces the defective component with an even more current iteration of bluetooth
really, for ~$36aud i am okay to try; it cost me only $3 less to confirm the local tech couldn't repair the e70, so for total expenditure $69 i will have "fixed" it, albeit will need to push one more button to fire up the music, and the dac component of the e70 is still great for my purposes (and i get to retain the 12v trigger off it so i can ignore the nad d3020 controller, which may be the worst remote i have ever had the misfortune to wave at the home theatre, although the accuracy and finesse of the air mouse i use there makes me look like i have a significant neurological deficit)
so, this baby :
Specifications:
▶ Audio Input: Bluetooth 5.4
▶ Audio Output: Coaxial/Optical
▶ Bluetooth Name: AkLIAM DD2 BT5.4
▶ Bluetooth Chip: Qualcomm QCC3084,support: SBC/AAC/APTX/APTX-Lossless/APTX-HD/LC3/APTX-Adaptive/LDAC(96KHz/24Bit), ,
▶ Power Supply: USB C,DC 5V
▶ Working Current: 13mA
▶ Size: 75*90*23mm
▶ Color: Black
fingers crossed it loves me long time
Its the Beelink PC. I had one and sent it back as it caused/introduced noise into the system.
I just received today an E70 velvet and connected it via USB to my beelink with N150 cpu, and the combination is dead quiet feeding directly to an LM1875 chip amp powered from different outlet, and the chip amp even has RCA inputs parallel connected to an LED audio vu meter powered with a separate 12v wall wart.
No hum, no hiss, dead quiet except for the music :)
I'm planning to use the E70 for volume control in preamp mode and it will be at three meters from the user so I need a good remote performance. Does anyone have the E70 positioned at that distance? Does the remote control work well at three meters?
I generally tend to recommend SMSL for best remote response. D6s, Raw MDA1 are both better than E70. And even DL200
it's fine
oh so much better than the nad d3020 controller :)
I switched to the SofaBaton remote, which works over wifi. You can position the IR relay/hub where you like.
(Or I use Roon volume in my other setup)
Mine works fine, so long as the room is not too bright. With plenty of sunshine in the room, the remote range becomes more limited.
Distance isn't a problem, and 3 meters isn't much; it will work from 5 meters. The problem is the angles, which are quite narrow, and you have to aim at the device. You can always buy a universal remote and teach it the Topping code, but that won't change the angles...
Got a bit of a bug with the auto-sensing feature.
My play is connected to it via USB and when the play starts, the E70 starts but when I shutdown the Play, the E70 stays on - it’s the same when I’ve used a Wiim Ultra to the E70..
Any idea why?
Any idea why?
are you using the 12v trigger?
is the usb on the Play still live despite it being "off" - computers often do that also
Yeah, I suspect that is the case .. I’ll try the other outputs on the Play ..
