Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Sorry if this was already discussed, but is hard to read all 94 pages:
can Topping E50 be fed only by the USB connection to the PC (cable length = 1.5m), without an external power supply ?
I had a Topping P50 Power Supply, but on my listening conditions, it did not give me any audible benefit, so I sold it. the good Topping User Support told me that any 5V 1A usb power source is eneough to the E50.
I hope they have been fixed the stand by issue also !
I have a big problem with the DAC failing to woke up from standby at first attempt in ROON.
I am gonna flash the firmware and comeback with feedback.
Edit:
Unfortunately, it was not solved !
There is somebody else here that has the same problem?
I am using Ropieee as ROON endpoint.
Maybe it is related to Ropieee, but I have to check.
Hi everyone,
as a - quite satisfied - E50 owner, I need your help to understand how to better setup the DSD playback in foobar2000.
Someone in this Gist argues that (every ?) DACs internally converts DSD to PCM so it's clearly better to perform it before sending the signal from PC...
...can someone clrify (and suggest the best settings for DSD playback) ?
I've always - since november 2021 - used mine in balanced (both TRS<>TRS and TRS<>XLR) mode and never noticed such kind of problem, btw I'll perform the firmware upgrade soon.
I do actually use foo_input_sacd (but I'm consideting the switch to foo_input_udsd)+ foo_dsd_processor + dsd_transcoder + foo_out_asio+dsd, but the question is: does E50 (= ES9068AS) really support native DSD or - as someone claims in that gist - it "will convert to PCM anyway and it probably won't do as good a job as the DSD2PCM plugin does" ?
I do actually use foo_input_sacd (but I'm consideting the switch to foo_input_udsd)+ foo_dsd_processor + dsd_transcoder + foo_out_asio+dsd, but the question is: does E50 support native DSD or, as someone claims in that gist, it "will convert to PCM anyway and it probably won't do as good a job as the DSD2PCM plugin does" ?
The ES9068AS' block diagram shows no native signal path for PWM (DSD) audio, so I believe it is converted internally:
Whether the DSD2PCM plugin truly outperforms the DAC chip's internal converter, would have to be measured first.
It is not a natural conclusion to make without evidence.
In their v0.3 Product Brief document ESS claims it "supports up to 32-bit 384kHz PCM, 96k S/PDIF and DSD1024 audio data" but they don't clarify which is the native one...
As you rightly said, the quality of DSD <> PCM internal / external conversions should be finely measured, however it does not make sense to convert - as I have done so far - PCM into DSD, right?
Last but not least: why in the world DAC producers do not fully exploit the potential of the chips that mount ?
The ES9068AS has integrated support for both analog and digital mics that would be useful for Realtime Room Correction applications...
I have switched to PC Realtek SPDIF optical-out to the E50 and operation is still impressively flawless like on USB. No lag or sample rate switching glitches of any kind, the auto on/off standby function continues to work like a charm.
The D50S/III is even better as toggling to USB or SPDIF will still continue to maintain the existing Bluetooth connection from a device. If would be more so if there's a function to auto-switch inputs based on user set priority so there's one less reason to hit the remote.
A far cry from SMSL and Fiio DACs where they always have annoying usability issues one way or another. In the case of the FiiO BTA30 Pro, not only is the buttons physically hard to toggle, it also doesn't remember the last input used when in DAC mode and SPDIF still has the SMSL-like startup lag.
