According to this drawing 14.5mm wide and my measurement ~ 14.3mm center to center, they will not.Will Neutrik and Amphenol TRS plugs fit?
afaik, TRS outputs of the E50 are actually balanced outputs.There is NO real reason to use "balanced" on E50 as is SINGLE ended (just like RCA).
The E50's TRS output is a 100% balanced output achieved through the combination of an op amp.There is NO real reason to use "balanced" on E50 as is SINGLE ended (just like RCA).
Lol, well I didn’t use my calipers but I did say “approximately”..Highly inaccurate I'am afraid.
I was reduced to measuring the typical width of an RCA connector then transposing that into a photo of the back of the DAC and then using that as a gauge to determine the TRS spacing.
You let me down badly when I needed you the most!!!
But that's typical of you and I have no idea why I maintain our longstanding relationship... maybe I have Stockholm Syndrome?
In all seriousness, I thank you for your effort and I really should have been able to determine it myself as the photo made it obvious only normal TRS plugs would fit.
Regards,
Peter
Have to say that I like the small form factor and have no issue with the TRS personally. Also heat really isn't an issue with DACs.
I have a TOPPING D10B and A30Pro with TRS outputs and/or inputs, and I have no problem using Neutrik NP3X plugs on either of them. So I'm not sure which other TOPPING devices you mention that are "shooting in the foot".Topping appear to have shot themselves in the foot with regard to the TRS spacing (or lack there of) on this DAC and others they have.
While I know that XLR is your experience and preference, can you please provide any reference to standards that indicate XLR should be used instead of TRS for balanced connections on consumer audio devices?Balanced connectors in consumer audio are XLR (as we all know) so what would it really take for them to make cases that support this.
I wouldn't mind TRS if Topping used better quality jacks. For me, it's about mechanical integrity. I service guitar amplifiers and pro audio equipment. I've probably replaced hundreds of cheap plastic jacks. Granted, they get more abuse in those applcations.I have a TOPPING D10B and A30Pro with TRS outputs and/or inputs, and I have no problem using Neutrik NP3X plugs on either of them. So I'm not sure which other TOPPING devices you mention that are "shooting in the foot".
I also have a stereo audio mixer with 0.5" (12.7 mm) spacing from top to top for the aux-send and aux-returns. While it does not leave much room to spare, I have no problem using Neutrik NP3X connectors here as well — a small space gap even still remains between the connectors despite that size. So given I can work within 12.7 mm, I'm not convinced that the TOPPING E50's 14.5 mm spacing is a real issue either.
In my audio chain, quite a few devices take only TRS or use XLR/TRS combo jacks, including the referenced TOPPINGs, stereo mixer, and RME ADI-2 Pro. Now granted, those are not strictly "consumer audio", so maybe TRS is perfectly acceptable for professional studio equipment while being against the standards for consumer audio devices.
Just to be clear: I'm not against XLR and have grown quite fond of them after spending too much trying trying to solder well within the tighter space of the Neutrik TRS connectors. Given the option, I'd also prefer XLR over TRS. My note above was simply to clarify that the TRS isn't a wrong answer (even on these TOPPING devices), even if it is not the preferred one for our purchase.
You mean the female TRS connectors that Topping uses on E50 are low quality?I wouldn't mind TRS if Topping used better quality jacks. For me, it's about mechanical integrity. I service guitar amplifiers and pro audio equipment. I've probably replaced hundreds of cheap plastic jacks. Granted, they get more abuse in those applcations.
Guess I was wrong, are they touching each other?My E50 is plugged with a pair of TRS Neutrik NP3X without hassles.
14.5mm plug overall diameter.
Are you using TRS<>XLR adapters connect to XLR<>XLR cables? If you are a better solution is to purchase TRS<> XLR cables.Guess I was wrong, are they touching each other?
No adapters per se. Either TRS<>TRS or TRS/XLR short cable to regularAre you using TRS<>XLR adapters connect to XLR<>XLR cables? If you are a better solution is to purchase TRS<> XLR cables.
There's plenty of space only for TRS to XLR cables...Guess I was wrong, are they touching each other?
