I don’t use to shake my DACs so can’t say if mine has something lose inside
Me neither but earlier today I was cleaning my desk and when I moved my E50 I felt something "loose" (not completely but not so well tight). Nothing more than that happened but I got a little scared.I don’t use to shake my DACs so can’t say if mine has something lose inside
May I ask you to gentle shake yours and report back? If it won't bother you...
Thanks! I really appreciate your attention!I did shake mine like a “maraca” and nothing felt loose inside!!
That's the noise. More, sometimes the button is unresponsive...I did shake mine like a “maraca” and nothing felt loose inside!!
I tried to knock on my e50, there is no such sound, it looks like you really have something wrong, but as for the button, I don't use it, I only use the remote control, it's much more convenient for me, maybe you didn't exactly hit the sensor, the main thing is that the device works as it should, and don't worry about it much, or unscrew the back panel and see what is not fixedThat's the noise. More, sometimes the button is unresponsive...
What balanced jacks should be used,? My x over has XLR in!!!!This is a review and detailed measurements of the new Topping E50 balanced USB DAC. It was sent to me by the company and costs US $269. I just reviewed its companion headphone amplifier, the Topping L50.
The E50 takes my favorite orange LED display and makes it even nicer!
It is a gorgeous bright orange display. A single button turns the unit on and cycles through the inputs. You also get a remote control:
As you see, power is provided through a 5 volt barrel connector. Topping provides a USB to barrel cable adapter so you can use any USB power supply.
As with more recent Topping products, it uses TRS output for balanced output instead of XLR which takes up a lot more space.
Topping E50 Measurements
As usual we start without dashboard. Let's test the balanced output with USB input:
Another exemplary performance from Topping, landing it almost at top of all DACs ever tested:
RCA output is nearly as good:
Noise performance is excellent as well:
Linearity is as perfect as you can get:
IMD performance is excellent:
I see a hint of ESS dac chip IMD hump. I wonder if that is what powers it.
Multitone performance is superb with almost no frequency dependency:
Jitter over USB is perfect:
It degrades just a hair over Toslink/Coax:
There are three filers available:
They impact our THD+N vs frequency thusly:
What can I say but another star performance from Topping. Company is so focused on squeezing every bit of noise and distortion out of these products while providing them to us at bargain prices. And in this case, great looks as well. I wish I could complain about something but nothing comes to mind.
I'm afraid this unresponsiveness can be related to the thing loose inside the E50 and this will might bring the device to fail earlier than expected.I tried to knock on my e50, there is no such sound, it looks like you really have something wrong, but as for the button, I don't use it, I only use the remote control, it's much more convenient for me, maybe you didn't exactly hit the sensor, the main thing is that the device works as it should, and don't worry about it much, or unscrew the back panel and see what is not fixed
I have not noticed this; I use Volumio and have used Moode. I might not be leaving it long enough. I do usually turn the PI off after use. I will perform a test.My E50 just came last week.
It has an annoying behavior and I'm wondering if somebody encountered this. I,m using it as Roon endpoint with RPi4 and Ropieee.
RPi is always on and the DAC enters standby when nothing is playing.
The problem appears when it has to wake up from standby state.
At first attempt to play something, tries to start and could not.
For a moment it not seen by Roon anymore, and at the second attempt the music plays.
Maybe there is a problem with Ropieee and the USB auto suspend.
D50s used before E50 was ok.
Ropieee has implemented the USB Auto Suspend feature.RPi4 USB ports are always ON so with a RPi4 + RoPieee your E50 wouldn’t go to sleep mode if it’s plugged into the RPi4 via USB.
Turn off the automatic standby function of E50 (the AUTO button on remote). After initial handshake E50 will remain turned on regardless on presence of +5V on VBUS USB signal from computer.The feature is working great with D10s, E30, D50s, but not with E50.
So... I've unscrewed the back panel (all the three screws) and it didn't come off. For others equipments as E30 and L30 this would be enough. Maybe there is something glued holding the back plate or more screws under the rubber feet.......and don't worry about it much, or unscrew the back panel and see what is not fixed
Since the size of the PC board of E50 is larger than that of E30, it is easy to make sound due to vibration.That's the noise. More, sometimes the button is unresponsive...
Thanks for your reply @Toku! It's comprehensive each E50 has a different behavior but mine is sooo loud that scared me. I had had some ideia how it would be build, I have seen some pictures from E30 and L30 (and already had removed the back plate from my units). No success on E50 though. In fact it's operating normally but this noise leave me some insecurity... If I learn how to open it I could check what's wiggling and fix it somehow.Since the size of the PC board of E50 is larger than that of E30, it is easy to make sound due to vibration.
The PC board is fixed while being inserted into the slits on both sides inside the aluminum case, and when it is vibrated, it shakes a little and makes a sound.
The way the vibration sound is produced differs for each E50. My E50 sounded quieter than yours.
I think that the touch operation of SEL is too fast and the touch time is short. Try operating it a little more slowly. It cannot respond to double touch.
I compared it with my E50 and it works the same.
I'm sorry, I corrected the previous post.Thanks for your reply @Toku! It's comprehensive each E50 has a different behavior but mine is sooo loud that scared me. I had had some ideia how it would be build, I have seen some pictures from E30 and L30 (and already had removed the back plate from my units). No success on E50 though. In fact it's operating normally but this noise leave me some insecurity... If I learn how to open it I could check what's wiggling and fix it somehow.
About my operation speed, yep, my anxiety makes me do things too fast. Actually it response much better if I touch slowly.
With regard to the double touch, I might be mistaken but double touch is not supposed to select the output?
Because in Tidal I have many crackling and the MQA could not stay because of that.
