Winning thing was kind of humor…..I don’t believe there is commercial bias. Here is more from the site. This is top mastering engineer.
Speaker cables were my first whistle-aha experience, sometime six to seven years ago. I had basic cables between the Classe amplifier and the Lipinski speakers, then in the middle of the session I switched to those that are still closed and I couldn’t believe my ears, this can’t be true. Depth was more pronounced, stereo image was clearer in many ways, elevation was increased. I really couldn’t believe if that was the case ”.
xxx has also done tests on its cables. He otherwise makes the recording in the same way, but changes one component in the chain - the intermediate cable, for example - and makes the different versions available to many people to listen to. The tonne-priced metric Vovoxes from the DA converter are the ones that have served as part of such a test. “I did a blind test between Mogam and Vovox for about the same price. The credit listeners to whom I sent recordings made with different cables all chose Vovox. You can imagine when a professional gang asks what was the difference between and against these music files - cables! They have chosen which one is better and given adjectives about what was better. ”
“Professionals are fools about the fact that if they feel there are differences, they can use a zero test to compare at the bit level whether that difference really was or not. When there are two versions of the same song, the second step is reversed and the files are summed. The silence of the result means that there are no differences. But when there are always differences in them and then it goes there on the side of preferences. Such a test is also very easy to distort. It is enough that the other one sounds 0.1 decibels stronger and everyone automatically chooses it better ”.
