fluxcapacitor
- Joined
- Dec 27, 2020
- Messages
- 115
- Likes
- 72
from one end to another, it's 122cm.Might be a stupid question, but does anyone know/can anyone share the length of the cables that come with the E50?
There's a firmware update related to volume adjustment, it could be related to this issue.Thanks for sharing this info Toku san. This is almost a show stopper for considering it as a pre amp.
I couldn't manage to play mqa through optical input. I downloaded foobar2000 and installed some components required but still no luck. I play mqa files downloaded from Tidal but still couldn't manage to activate mqa led on the screen can you show me you foobar2000 configurations? thanks.As soon as the Topping E50 I ordered arrived, I performed the operation test, so I will report the result.
Until now, I mainly used E30 and D10s D10 Balanced for DAC, but I bought the newly released E50 because it can also play MQA.
Immediately after arriving, I checked all the basic operations. The genuine AC adapter of iPad is used for the power supply. The PC is Windows 10 Pro and the audio player is using Foober2000 and TuneBrowser in ASIO mode.
I did a continuous playback test by randomly switching between PCM44.1kHz~784KHz/16~32Bit and DSD2.8~DSD512, but there are no problems to worry about.
I tested PCM44.1~192kHz (16/24Bit) using the OPT/COAX output of D10s for the input of OPT/COAX, but it also plays back without any problem.
I used to use the SMSL M500 to play MQA, but the E50 is a big improvement.
On the M500, when MQA is played, it will be PCM playback at first and will switch to MQA after 3 to 4 seconds. At the time of switching, the sound was interrupted for a moment and could not be played smoothly, but with the E50, when MQA is played, the MQA is displayed instantly and playback starts. The sound is not interrupted like the M500, but there is a small click noise.
With the E30, I had a habit of making a slight click noise when switching songs or during sleep/wake, and I was a little worried when I connected the power amplifier directly, but with the E50, this is completely silent. This is a nice evolution. The product has been energized continuously for a long time since it arrived, but I hardly feel the heat generated by the main unit.
The brightness of the display can be adjusted in 3 steps, and automatic ON/OFF can be selected, improving usability.
Problems I noticed
When using USB input in pre-mode, the volume is suddenly maximized when the volume is lowered from -0.0 to the minimum value of -99. This symptom is the same for both balanced and unbalanced outputs. It is completely normal when inputting OPT/COAX.
If you operate the volume without knowing this, it will cause serious troubles such as destroying the speaker. I immediately reported this issue to Topping. I hope it will be improved as soon as possible.
---- postscript ----
This issue only occurs when playing DSD.
The E50's COAX / OPT input supports MQA, but my PC environment doesn't have a COAX / OPT output and I haven't tested this.I couldn't manage to play mqa through optical input. I downloaded foobar2000 and installed some components required but still no luck. I play mqa files downloaded from Tidal but still couldn't manage to activate mqa led on the screen can you show me you foobar2000 configurations? thanks.
I think it only adds convenience (internal PSU) and looks. Also, no mqa
The ESS dac chip can decode MQA on itself, can't bypass that.Yes, MQA based on the description:
TOPPING E50 ES9068AS Digital to Analog Convertor (DAC)
Specifications: USB IN: PCM 44.1kHz-768kHz/16bit-32bit DSD DSD64-DSD512 (Native), DSD64-DSD256 (DoP) MQA Full Decoding COAX/OPT IN: PCM 44.1kHz-192kHz/16bit-24bit DSD DSD64(Dop) MQA Renderer Decoding ...shenzhenaudio.com
If MQA can be played smoothly like PCM and DSD without any problems, it is acceptable to install MQA, but it is far from satisfactory playback operation although it has evolved a little. In my personal opinion, the E50 doesn't need an unfinished MQA.If you want, pay extra fees for lossy format propagated as lossless. I removed MQA label form my E50.
Topping E50 Review (Balanced DAC)
measurement cannot standing every thing what does that even mean?www.audiosciencereview.com
There are plenty of studio quality XLR-TRS cables, so no that won't happen. And oh wow, you can hear DACs through YouTube videos, amazing....There is comparison in youtube between su 8 and e50. Even thru youtube you can hear that sound opens up a bit with e50, more height. And here people say you can't hear the difference. What's that all about? Go and listen.
Ps. Johnyang1997, make this v2 with xlr plugs, we have expensive xlr cables to active studio monitors. We don't wanna compromise quality with cheap trs plugs. I am ready to ditch su8 after I heard comparison.
just buy a good cable with quality connectors. like this oneWe don't wanna compromise quality with cheap trs plugs. I am ready to ditch su8 after I heard comparison.
5 Foot - Quad Balanced Patch Cable CUSTOM MADE By WORLDS BEST CABLES – using Mogami 2534 wire and Neutrik NC3FXX-B Female XLR & NP3X-B TRS Stereo Phone Plug. : Musical Instruments
Buy 5 Foot - Quad Balanced Patch Cable CUSTOM MADE By WORLDS BEST CABLES – using Mogami 2534 wire and Neutrik NC3FXX-B Female XLR & NP3X-B TRS Stereo Phone Plug.: Microphone Cables - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
So your vovox cable costs more than the Topping E50. A true sign of genius..Thank you, I got 300 dollar vovox xlr, can't start playing around.....must be xlr.....ofcourse there are many balanced dacs out there. Only this straight comparison to su 8 in youtube convinced me that e50 has little edge and price is right.
OH MY!! BS-o-meter on full tilt.There is comparison in youtube between su 8 and e50. Even thru youtube you can hear that sound opens up a bit with e50, more height. And here people say you can't hear the difference. What's that all about? Go and listen.
