Topping E50 Review (Balanced DAC)
Thing is i dont even need good specs, all i need is three things from a dac. PEQ, optical inputs and hardware mixer capability (or offers a compatible volume knob dial which i can use instead). The e70 is great for desktop use cause it has a reachable knob, but for living room use i genuinely do not know what to get
Preamp?
Just not sure what your needs are. E50 II came to mind if you didn’t already habe the E50.
Fosi Audio has preamp and also a S3 Streamer that has optical in/out with volume control that might fit your needs.
I sent topping an email asking if the E50 II has a discoverable hardware volume mixer for linux/alsa use. If it does ill buy it but if not then im not really sure what to get
I use the e70 in a bedroom and it works well. It replaced a d50.
I’m using it, effectively as a preamp.
Ninety percent of the time, I’m using the remote but use the knob the other 10% of the time.
Inputs are a RasPi streamer via toslink and a Sangean HD receiver via coax. The DAC automatically switches between the two sources and the e70’s 12v trigger powers up my amp when the source goes live. It works well for me.
Granted the e70 was a bit more expensive than I mint
Great job, @JohnYang1997 and excellent review, @amirm as always. I think the Topping E50 + L50 Combo is going to be the perfect companion for a Raspberry Pi 4 with Display running RoPieeeXL (Roon Bridge) to set it up as Desk Roon end point. Literally a full streamer for less than $700. What a bargain!!!
Tell a little bit on how that system would be. Could I stream music from my PC audio files by Ethernet?
I have Topping e50 ii - Firmware update is required- can t do it--no way, tried 100 ways, it wont be recognized by the Topping site, and I can t find the remote control.
Finally l could update the firmware. !!! You have to install Topping Home in windows 11, which l don t need, since l use the dac on my TV set and wiim. System 2- so to say, Dac was not recognised by the pc, a lot of swearing and changing usb cable inputs, finally it was ok. Thanks for the attention BTW.
Try a different browser. Firefox didn't work (no recognition) for me on Win11, Edge worked fine ..... regarding E50 II update.
I run Day Sequerra HD tuner into my E70 V. It requires a AES transformer to convert into coax.
I had converted the optical output from a Sangean to coax a long time ago. Benchmark used to have instructions in their tech notes. John said it was lost in updates, did not know if anyone ever used it. Back then coax transmission had way less jitter than optical. Not anymore.
Prior to your post, I’d never heard of Day Sequerra. Looking at their specs, the tuners seem impressive (but possibly expensive.)
Which receiver do you have? Was it, in fact, expensive?
As I type this, I’m actually listening to the news on my Sangean HDT-20. I looked back at the Amazon invoice and paid $150 + tax in April of 2021 for the tuner and have gotten far more than my money’s worth from the Sangean.
The user interface and lack of a super capacitor to store stations in the event of a power loss are my biggest gripes. I actually bought a small UPS for $50 to address this problem. Why a manufacturer won’t spend an extra $0.50 for a capacitor is beyond me.
Even so, $150 for an HD receiver seems very reasonable to me.
Bottom line: the Topping, Sangean, RasPi, Audiophonics Purifi amp and the Elac UF5s they all drive make for a nice listen to news, sports, video, podcasts or great music. I’m quite pleased.
Not many home listeners to HD Radio. Shame. Many stations have upgraded their equipment and offer excellent Sonics.
There are two excellent stations here in Houston where the HD feed is better than the internet quality.
Think the Sangean I modified for coax output is a HDT-1X. Brian Beezley did a lot of testing and design for these. Think about 20 years ago.
The Day Sequerra broadcast monitors are radio station equipment. Excellent. They show up on eBay. One of my favorite local stations suffered a catastrophic equipment failure. The HD feed was offline for months. When it came back, BAM. Excellent quality. The station manager told me the replacement equipment was much higher spec. And the engineers were able to tweak wider frequency response, lower distortion, lower noise, and better separation. Said CD quality. If sixteen bit, excellent. Sounds high quality.
