r4ndomw4lk
- Joined
- Dec 28, 2021
- Messages
- 1
- Likes
- 0
I've recently bought Topping E50 with L50. I'm pretty happy with it, however I encounter cryptic "PNL error" always when playing certain tracks, which bothers me. I contacted Topping customer service but after two weeks of exchanging e-maiIs I feel that it is going nowhere. I was also unsuccesful in finding any information in the Internet about othe people encountering this issue. So, it is not clear to me if it is exclusive to my unit and I should try to replace it, or it some wider problem with E50 and then maybe I should return it. Therefore, I would greatly appreciate it if someone with E50 tried to replicated the error with their device and let me know how it went.
The procedure is simple:
- Play one of the tracks below in Tidal (both are first when you open the links):
1. Cloud Boat - Man of War (Phaeleh remix)
2. JUDGEMENT NIGHT (SIDEWALKS & SKELETONS RMX) - HEALTH, Ghostemane
- Few words about the setup:
1. Make sure that Exclusive Mode, Force volume and Passthrough MQA are switched on in Tidal.
2. E50 should be in version 1.06v (latest). I use it in DAC mode and it is connected directly to power socket.
3. System sampling rate is set to 44.1 kHZ. The error happens on both Windows and macOS.
Thanks!
Thanks!
