Topping E50 II DAC is up on the Topping Store
It might not make much sense to you, but believe me, I have seen quite impressive differences in measured (in-room) treble response just because someone was standing in a slightly different spot, or had knocked the mic a few centimeters off...
I asked if you would post your multiple measurements you stated you had done (that would help address those concerns). You declined. Why?
I already responded to that with the fact I was nowhere near the microphone when I was doing mesurements. Microphone was not knocked a few centimeters.
"Help address those concerns?" What do you think this is?
If you don't want to trust measurements, fine, your decision.
At least I fixed my problem, once I stopped using XLR on FOSI V3 Mono and started using its RCA, the sound became "normal" and I could actually enjoy the music.
I already responded to that with the fact I was no where near the microphone when I was doing mesurements. Microphone was not knocked a few centimeters.
If you say so. How many times did you measure?
I want to trust measurements, but they have to be properly controlled and verified.
Several of you pointed at *room* which made no sense. You said "you cannot measure same thing twice and get same response" which also didn't make much sense.
Use RCA inputs with FOSI -> one frequency response. Use XLR inputs with FOSI -> different frequency response. Everything else, unchanged, speakers included.
It could be the Fosi, and not necessarily the E50 II. The measurements show that it's load-dependent (IMO, even though amir says it's not, the graphs kind of show that it is a little):
No one said it was E50 II. :) It most likely is Fosi, measurements show it.
Tbh, I wouldn't respond either. I know it's normal for ASR, but on any other forum, it's the equivalent of a troll post.
If I post on a computer forum that I'm getting error 5003, and someone says to post a screenshot or log file, that's fine. If after I post the screenshot/log file, someone says to post a video of my monitor with my phone holding up today's newspaper to prove I really got the error, then I'm not going to do it.....
Because unlike the other forums you refer to probably don't have "Science" in their name.
A better comparison would be "My screen is hard to read - here is a measure of the brightness of the screen". Yes, the screen brightness might be too low, but it could also be that the sunlight from your window is too bright - or you forgot to wear your reading glasses.
Picked up an e50 ii on Amazon. Nice unit with deep base, but sounds a little muffled compared to my other (ESS) smsl DAC.
Annoying how quickly the power down would time the unit off. Did not seem to be able to ajust using the topping app.
The main issue I had was pairing with the wiim pro, via coax or toslink. Maybe it's a data mismatch, but I got constant static over both digital inputs, with a flickering input light for both. (USB in from my CD transport was OK.) Tried syncing signal settings between wiim and e70, adjusting power cabling, etc, no improvement.
Wiim pro works just fine with my smsl dax from both coax and optical so its not the streamer.
Too many issues/compatibility. Will use Amazon's free boxing to returned via whole foods.
Just set my e50 II up; no audible difference compared to e30 II but balanced output to my active monitors is an improvement for system cleanliness. No issue pairing with WiiM Ultra via USB.
A question about the E50 II PEQ: is it possible to have different equalization profiles for the Left and Right channels? I have hearing loss in my left ear but not my right ear, so this would enable me to adjust the sound in my headphones to compensate for my hearing problem when I listen to music.
You can store three EQ presets. 10-band PEQ. Independent Left/right tuning. Filters are peak, low-pass, high-pass, low-shelf, and high-shelf. +/- 12db per EQ band. Q range 0.1 to 15. Preamp gain +/- 12db. No all-pass, no delay, no phase rotation tools. Sample rate limitation is up to 192khz for PEQ. Low-pass is interesting to have.
New firmware
6. What's updated​
*New: Added power-off saving for UAC selection.
*Fixed: Compatibility issue between UAC1 and PS5.
New firmware
6. What's updated​
That doesn't even sound worth the risk of flashing firmware.
I performed room correction using REW and an ECM8000-U microphone, and the resulting correction curve was extreme (left channel):
1 True Auto PK 48.25 -17.00 5.565
2 True Auto PK 75.50 -4.10 7.403
3 True Auto PK 92.90 -4.10 10.270
4 True Auto PK 116.0 -15.90 7.375
5 True Auto PK 494.0 -4.50 4.870
The Topping E50 II PEQ allows for a maximum correction of ±12 dB. Can I stack two filters (10 dB and 7 dB) to achieve 17 dB? Should the Q value be reduced by 15–20% in such a case? It would look something like this:
Preamp: 0 dB
Filter 1: ON PK Fc 48.25 Hz Gain -10.0 dB Q 4.60
Filter 2: ON PK Fc 48.25 Hz Gain -7.0 dB Q 4.60
Filter 3: ON PK Fc 75.50 Hz Gain -4.1 dB Q 7.40
Filter 4: ON PK Fc 92.90 Hz Gain -4.1 dB Q 10.27
Filter 5: ON PK Fc 116.00 Hz Gain -10.0 dB Q 6.05
Filter 6: ON PK Fc 116.00 Hz Gain -5.9 dB Q 6.05
Filter 7: ON PK Fc 494.00 Hz Gain -4.5 dB Q 4.87
Or would it be better to leave the PEQ to Neutron (Android)? Android -> CCA (Toslink) -> E50 II -> Topping Mini 300
high output voltage which is very nice if you plan to use a Purifi class D power amplifier module in the future.
Do you mind explaining the benefits of the high output voltage when using a purifi based amp with gain selection?
Sending a strong signal directly from a DAC to the power amplifier usually results in a better signal-to-noise ratio. This is because you avoid having to amplify a weaker voltage later on, which would also amplify any potential noise in the signal chain.
Sadly, my Topping E50 II has stopped working after about seven months.
It first began producing garbled audio that would temporarily clear after restarting the DAC. I later noticed that switching inputs would also restore normal sound, but usually only for a couple of minutes. Over the next few days, it continued working for random periods before the garbled audio returned. Eventually, it stopped producing sound altogether and has remained silent for the past week.
To rule out other causes, I tried a different source device, replaced the optical audio cable, and updated the firmware, but none of those steps made any difference.
I otherwise really liked this little DAC, especially because the built-in PEQ was very useful for headphones. I had considered replacing it with the DX5 II, but that model also appears to have some reported reliability issues.
