Topping E30
Madmac
Hi all,
New register but long time lurker.
I have a Topping E30 with very little use and recently it just goes on STBY after a few minutes working. It can work for a minute, 10, 30... If I press the power it resumes working as normal until it fails again.
Anyone knows what might be causing this?!
It's powered up by a linear regulated power supply that also powers my RPI without issues.
I've tried to disassemble it but there a data ribbon connecting the board to the screen and I'm not really sure how do you get it out as you can't pull the board out enough to access it.
Any help will be much appreciated.
Have you tried hooking it to a different power supply to see if the power supply is the issue? That would be my first step.
