Where does this actually come from?..The E30 ll's COAX/OPT S/PDIF connections have been greatly improved over the E30, so I'd like to see how they work.
Noise and harmonic distortion are slightly lower than OG E30I have the original Topping E30 and L30. Does the E30II have a significant sound improvements over original, considering the Velvet Sound and (though the same 4493 chip) the dual chips, to consider 'upgrading?'
Remarkable stability against the background of the provided level of confidence! )) - https://www.audiosciencereview.com/...topping-e30-ii-dac-review.36028/#post-1261246
Be careful. E30 II has a problem with TIDAL.I liked the way the E30 worked, so I bought a total of three.
The E30 works very well in preamp mode when plugged directly into a power amp.
Some users consider the extremely small click noise that occurs when switching songs to be a problem, but I think it works perfectly. Compared to other DAC products, the E30 works perfectly and is an excellent DAC.
I also have two E50s, which are the higher end models of the E30s, and plan to purchase more E30 lls.
The DAC just plays what your Mac is sending to it via USB.This DAC has a problem with volume handling in the pre-amp mode.
TIDAL plays via USB on Mac.
Some songs are too low in volume, other are too loud.
It's as if E30II does not know what is 0dB.
Very disappointing.
That is simply not true.The DAC just plays what your Mac is sending to it via USB.
If you have inconsistent volume, then it's Tidal who is to blame, not the DAC.
Unfortunately your description gives too little information.That is simply not true.
I don't know if tidal sending 24bit vs 16bit files makes TOPPING E30 II lose the correct 0dB or what, but it does have problems.
No other DAC has that problem (SMSL, Bechmark, NAD, other toppings and many others I use).
It would be nice if you could explain in a little more detail what you did to reach that conclusion.
I suggest playing music files stored on the MAC directly on the MAC instead of Tidal once to see how the E30 ll behaves.
Based on the information I got from you now, I also guess that MAC + Tidal is the cause.
The E30ll can only reproduce the input signal as it is.
If you set the volume to 0.0db you will never change it. There is also no function to change the sampling rate arbitrarily.
What is the specific model name?
However, in the past, there was a ridiculous mistake in the volume control of the Topping E50 immediately after its release, and the firmware was corrected immediately. But in your case such a mistake is inconceivable.
Thank you for providing the information. I understand your situation.DAC: Topping E 30 II
Player: TIDAL
OS: MacOS
Steps to reproduce:
1. Play a song with (MASTER) quality marker
2. Play a song with (HIFI) quality marker
Observe that the 0dB volume for song in step 1 is MUCH louder than 0dB volume for the song in step 2.
P.S.
Sampling rate is dictated by the OS not by the DAC.
MAC + TIDAL is NOT the cause.
Other DACs that work just fine:
Benchmark DAC 1 HDR, NAD M51, SMSL SU-8, Topping DX3 pro, Chromecast Audio.
This is a DAC issue.
Hi, have you tried to play with loudness normalization in Tidal? (Tidal->Settings->Streaming->Loudness Normalization) I had some problems with it some time ago.DAC: Topping E 30 II
Player: TIDAL
OS: MacOS
Steps to reproduce:
P.S.
More information I have.Thank you for providing the information. I understand your situation.
I'm looking for the symptoms you're experiencing from my knowledge and experience, but I can't find anything that matches.
I take a moment to think about the possible causes of the symptoms.
2 thoughts on this.I have another problem now. E 30 II randomly disappears from MacOS. Had to turn it off and on several times and now it no longer works... Mac says Device not found. Can´t play anything over it. It's display shows USB and Volume / PCM.
After several on and off, it is recognized again and works again.
Why?Also, the USB cable should not be too short, better at least 50cm.
