I love the look of this dac. Very discreet and can sneak it's way into even the mightiest of sound systems!
Can this also be used as a spdif converter?
E series seems to be replacement for D series. Better performance for similar price.What's the difference between D series and E series?
Yikes, yes, this is my concern. While Bluetooth is already lossy I would prefer not to further degrade the signal with conversions before sending it to a DAC.I usually check the inside... I have one bluetooth receiver that takes the analog from the BT chip and feeds to an ADC for the SPDIF out.
Bluetooth lossless?Yikes, yes, this is my concern. While Bluetooth is already lossless I would prefer not to further degrade the signal with conversions before sending it to a DAC.
If Topping could put this DAC inside of their MX3 and upgrade the amplifier section they'd have a real monster on their hands.
Sorry, meant to write lossy -- good catch. As far as I know even aptX HD is not truly lossless.Bluetooth lossless?
DACs that measure well for under $130, not as common as you'd think. If by "Good" DAC you mean anything that sounds as good as a $10 Apple dongle, then I agree. I think people are just impressed at the measurements, which requires a bit of engineering effort (whether you can hear these efforts is a whole other discussion)Good DACs these days are dime a dozen IMO. Although am curious on pricing.
YES to AES out. Although Singxer has a $429 adapter that converts USB digital into AES, SPDIF and IS2:Great low cost option for entry level DACs, good job Topping. Hey @JohnYang1997, let Topping know there is some interest in an E10 interface, with USB in and SPDIF/I2S/AES out
I think D series has balanced XLR analog output, right?E series seems to be replacement for D series. Better performance for similar price.
Makes sense, maybe.
Is the move to AKM part of the E series line? Are the latest 4.82 drivers also compatible?
Of course not.Does it make any switch noises like my DX3 pro?
