D
Deleted member 9286
Guest
What are obsolete for certain are D10 and D30!
The D10 still has a role to play as a great little USB to SPDIF converter.
It does seem so. My only remark here is the lousy AKM digital filter. Whyyy do they make it so slow.
Oh well.
When I read the datasheet it seems that the digital filters are shared to each two sample rates. Meaning 44.1khz and 48khz use the same "slow" filter which is ok for 48khz but not 44.1khz. On the other hand, no I don't think there's big enough differences between digital filters in one of my previous experiment here in this forum where I blind tested trying to prove the difference of digital filters. I did hear a bit difference but that's tiny.Maybe you discovered their "Velvet sound" secret sauce. To be honest, I wouldn't be able to hear the differences at those frequencies.
That website looks very sketchy. Likely to be a scam. Beware.
https://www.audiosciencereview.com/...adphone-amp-reviewed.9446/page-30#post-270481
Objective speaking, E30 has lower distortion harmonics, similar DNR/SNR, similar noise, much better multitone performance but for a bit more expensive price. The m300 mkii is better in noise but the multitone really falls short, which is not even as good as the Sanskrit.Source?
I see the opposite: https://www.audiosciencereview.com/...t-of-smsl-sanskrit-10th-ak4493-edition.10830/
The update version of D10, D10s is coming out with SPDIF and COAX out. But not so much with the I^2S and the AES out. The physical dimension of AES XLR is not able to fit in those small boxes. While there's some interests, I don't see it coming in the future. But I may be wrong. We'll see.Great low cost option for entry level DACs, good job Topping. Hey @JohnYang1997, let Topping know there is some interest in an E10 interface, with USB in and SPDIF/I2S/AES out![]()
Sorry, I was looking at the measurements of the first version.
Here E30 wins on linearity and multitone, while Sanskrit 10th MKII wins on THD+N vs frequency, with the rest of the measurements being more or less even. I don't think there's a clear winner.
From other perspectives, E30 is going to be a better pair with the incoming L30 headamp. If you have the sp200 you might go with the M400 which isn't out yet. But that's a higher price bracket altogether. I like well rounded performer not good in single test but good in all of them. The distortion of sp200's XLR output is really great of -130db up to 10V with 16ohm but its noise performance can be a deal breaker for some. Also once you turn the potentiometer from 0db/maximum the distortion is highly increased due to the relatively poor voltage coefficient of the carbon taper.
But it's not 115 db. So it's a hard pass! /sView attachment 54930
Not knocking nor trying to educate or anything. This is what we got for dashboard. The small peaks around 1khz shouldn't be there. I would like to know what caused it.
PS: I didn't design this this time.
I don't know about the sample rate. It doesn't seem to be any wrong. But the dac chip is definitely 4493 not 4497.@JohnYang1997
while looking up the Sanskrit, I found this Aliexpress listing which mentions 768KHz support: https://www.aliexpress.com/item/4000785916611.html
and this one which mentions the AK4497: https://www.aliexpress.com/item/4000785137648.html
I assume that both are typos?
It's the only one out of 7 that says 768. All the others say 384. It looks to me like a mistake in the marketing material that most shops corrected before they put it online.I don't know about the sample rate. It doesn't seem to be any wrong. But the dac chip is definitely 4493 not 4497.
It's probably the only one who says 768khz is correct. You may contact SMSL for this. I believe it's 768khz.It's the only one out of 7 that says 768. All the others say 384. It looks to me like a mistake in the marketing material that most shops corrected before they put it online.
yeah of course. It's all just marketing at this point.It's probably the only one who says 768khz is correct. You may contact SMSL for this. I believe it's 768khz.
And well, who should care about that when there's no 768khz recordings to be found.
