Topping E30 DAC Review
Thanks for linking that thread aswell. Looking inside doesn't show any blow transistors or anything that I can see atm. I will maybe keep at it and see what I can find
I reached out to Topping support email that I found on their website, it seems like Its possible for me to buy a main board directly from them? It doesn't seem like a bad deal if this is actually legit, I took the service email from their website.
I reached out to Topping support email that I found on their website, it seems like Its possible for me to buy a main board directly from them? It doesn't seem like a bad deal if this is actually legit, I took the service email from their website. View attachment 465045
tpdz.net is Toppings official website. I download the newest ASIO drivers and firmware updates from there. This seems legit to me.
Does anybody know the specification for the Barrel connector to USB lead that usually comes with the E30 DAC.
I recently moved house and the lead has gone missing. I suppose I am looking for an after market solution.
Any help would be warmly welcomed. I am in Australia.
Cheers
It's a standard 2.5mm/5.5mm DC power jack.
Thanks for that, I scoured quite a few pages of this thread looking exactly for that and came across the same information simultaneously as your reply came through.
Much obliged, ordered a replacement from Amazon straightaway. Thanks again,
Late reply, but I'll reply anyway. For 71 USD it should probably be possible to buy an used DAC instead
Just checked eBay and there is a used black E-30 with remote for $69.99 plus $11.55 shipping.
1.08 is the latest one they got for this model (last updated in 2020)
V1.08 is the latest and all E30 > ser 2006 already have 1.08.
There are no newer versions for E30.
That firmware fixes polarity issue for USB input only (SPDIF/Toslink still has flipped polarity).
One annoying thing ... if a signal is missing the standby follows after seconds - too short. A switch-off the digits ...
Is the connection OPT/COAX or USB? If it is a USB connection, the operation will depend on the USB settings on the PC.
I have one E30 DAC. Working on my tv set. It works perfectly, signal goes to a Topping pre amp, then two amplified studio near field monitor. No firmware upgrade ever.
I need DAC for Toslink
I already have usb Topping DX1 + L30 and I like this DAC for headphones. My idea was to buy the same DAC for my setup with Airportexpress + amp Yamaha 701 + passive Speaker setup
Idea was to change internal Airport DAC to Topping E30II connecting them by Toslink
Sometime I will use USB + notebook , but basic scenario is Toslink
But suddenly I saw that Toslink in E30II is not perfect. As I understood E30II lite has the same issue.
Will SMSL SU1 be better solution for my idea? Or may be I should overpay for E50 ?
