Gradius
Yes, of course.If firmware V2.10 is installed, I think the E30 is a CS8416 version model.
I opened before.
Doing it now, swapping the 2 DACs and listening the music. Then decided to give it a try with the new opa.Why don’t you try a controlled listening test first, before you do disassembling and grabbing your soldering iron?
That doesn’t sound very “controlled”. At the very least you’ll need to level match. Better would be to test blind, so let someone else change the DAC’s.Doing it now, swapping the 2 DACs and listening the music. Then decided to give it a try with the new opa.
It's valuable thanks anyway.That doesn’t sound very “controlled”. At the very least you’ll need to level match. Better would be to test blind, so let someone else change the DAC’s.
I see, in that case it's more sensitive to output impedance.AK4493 has voltage output, not current.
Vs: +-13VAD8620 is pretty old, like from 2001.
OPA1612:
Supply Voltage: 4.5V ~ 36V
THD+Noise: 0.000015%
Common Mode Rejection Ratio: 110dB to 120dB
Gain: 130dB
Gain Bandwidth Product: 80MHz
AD8620:
Supply Voltage: 5V ~ 13V
THD+Noise: 0.0006% ?
Gain: 105dB
Gain Bandwidth Product: 25MHz
I still didn't performed a critical listen with OPA, but so far, sounds pretty decent.
Sounds like nonsense to be honest, classic audiophile self delusion. That's the point of this site, to stop people like you wasting your time & money.I do not beleive. It sounds scrap
Arrived today my long waited E30. Read a lot of good thing about it before decided to buy. Then after plugged in turned to be so disappointed very
Dull, shallow deeps, metally sounding highs.
I'm comparing it to to my old FX-AUDIO DAC-X6 modified one (replaced every opamp to AD8620 + big analog PSU) - which sounds lively, deep, air, 3D. Very good compared to E30. But it's old, used and mainly for my Sennheisers next to my PC ... so bought the E30 for Volumio to the room.
Testing witgh NAD316 + Wharefedales...
The E30 is way below the DAC-X6 I'm shocked
I remember the FX had similar sounds before the opamp update, so decided to replace the OPA1612 to AD8620 (I have many from decades ago when it appeared and ordered original samples), but I'm in trouble.
It needs some special long screwdrivers to dismount the front panel internally to be able to disconnet the cord which connects the main board to the front display.
Could someone please help me how to disassemble the E30?
Thanks!
the DAC's I/V differencial output load causing huge dinamics diffence in sound, which is almost unmeasurable with steady signals.
Thanks!
I have the E30 and the FX-Audio DAC-X6 as well. I use the E30 between a RPi and a Yamaha amp, the FX-Audio is used in my garage now, feeding a car stereo i hooked to a 12v battery topper. Sadly, i missed the time window to send the FX-Audio back.Arrived today my long waited E30. Read a lot of good thing about it before decided to buy. Then after plugged in turned to be so disappointed very
I'm shocked too, my dude, but for different reasons.The E30 is way below the DAC-X6 I'm shocked
Changing the OPA out for something else doesn't help when the DACs reference design was murdered. And it was murdered. Slaughtered even. It's a bloody mess.I remember the FX had similar sounds before the opamp update, so decided to replace the OPA1612 to AD8620 (I have many from decades ago when it appeared and ordered original samples), but I'm in trouble.
I had the 301, 501, 701 around and have to say i was very impressed actually. I couldn't tell the DAC apart from anything and think the amps are incredible value, peak value is the 501 IMHO.I could feel a difference from this DAC vs Yamaha AS 701, I like E30 better. Also, for a small integratwd amp with bad sound, things improved a lot when I used E30.
Depends on the max voltage needed by the power amp. It should be around or less than what the E30 is able to deliver. Do you have a specific model in mind?However, my BIG question for today: is there any reason not to consider and use E30 as a LEGIT PREAMP with a quite powerful (Rotel) power amp? Thanks
This one seems to be an edge case.I wonder if there's a person out there that thinks a Topping E30 is worse than a Aimpire AD10
