The E30 is a better DAC and a better value (case, remote, standalone capability), but in terms of whether or not you'll hear the difference, probably not.hi,
would this (e30) be superior to the khadas tone board 1 as a dac?
i already have the khadas connected to my pc as a dac and i was wandering if there would be any difference with the topping e30... ?
i want to try something else and i want to know if the e30 would justify the expense...
Yes the usb input uses xmos asynchronous.Hello.
Can someone tell me if the E30 is asynchronous ?
I quite can't find the answer..
I plan to plug it to a RP4 with usb.
Thanks.
thanksYes the usb input uses xmos asynchronous.
Is the E30 still considered a good DAC?
May I know how people find out about phase issue? Is there a specific frequency for which I should listen?
Thanks!It was evident in needle pulse plots.
With some particular music and a good reference it can be audible to trained listeners that know what to look for.
Thanks!
How would you describe the hearing sensation of phase issue?
I don't hear it when using headphones setup. But with stereo setup, when using E30, certain notes (loud high bagpipes notes) would feel like they are playing very close to both ears. With X16, same notes would appear on a stage in front of me.
The test is good for both headphones and speakers system? Thanks!Try doing this test. I was surprised that I was able to hear the difference pretty much every time. The pauses between the strumming make it easy to tell for me.
Just did it with headphones via my smartphone. 5 out of 5.Try doing this test. I was surprised that I was able to hear the difference pretty much every time. The pauses between the strumming make it easy to tell for me.
Just did it with headphones. 5 out of 5.
Just now I tested with my phone as player. I will try e30 soon. I read that for certain frequencies, the issue won't show with headphones. Only would show with speakers. Not sure exactly what frequency.Well, then that rules out that you have the same effect since you only seem to have it with speakers.
