Billbass1
- Joined
- May 16, 2021
- Messages
- 12
- Likes
- 7
So I upgraded my DAC and bought a Topping E30. It arrived today and I hooked it up to my system. The optical audio out of my TV sounds great and is an overall improvement from the FiiO D03K DAC I was using the past few years. Next I hooked up my old Phillip’s CD player Using the coaxial out. That’s when it started having a major issue. At first I thought the CD player was skipping around on the song I was playing. It would play ok for a few seconds and the sound would cut out for about a half second. This just kept repeating over and over . Than I hooked up a old Toshiba HD-DVD player using the optical out. Put the same CD into that player and got the same exact results I that I had with the CD player. Next I hooked up my Panasonic Ultra HD player again using the optical out. And again got the same awful results. I have the Topping E30 set in the DAC mode. There is not much in the way of to many more adjustments on this unit. I thought perhaps I had to manually change the bit rate between using the TV and the players but there does not seem to be any way of doing that. Funny thing is my old $18.00 FiiO DAC has no problem playing any of the players or TV. Anyway, I sent Appo Audio an email describing the problem and I am awaiting a response from them. Meanwhile, if anyone here has any solutions or knowledge, I would greatly appreciate hearing about it. Thanks
