Topping DX9 - teardown
whydan
Hello,
It's kind of surprise to me when knowing that DX9 used AKM AK4499EQ.
We already knew that was a fire broke out AKM foundry on 2020 and they gave up to rebuild on 2021.
AKM chose to be a fabless design house and the new AK4499EX announced on 2023 as outsourcing.
AKM separated AK4499EQ as two ICs, AK4191 as digital processing and AK4499EX as analog converter.
But new AK4499EX only has 2ch output so you can image that AK4499EQ = AK4191+2*AK4499EX.
That's why AK4499EQ is more valuable to me, AK4499EX is more like a cost reduction one.
I have done couple of AK4499EQ DAC teardown report before, so I won’t miss DX9.
Unbox
DX9 is the 15th anniversary DAC so it is more luxury than others, even the package design.
And also marked 15th anniversary wording on top cover.
Inside, the DAC, the thank you card, remote control, BT antenna, 3.5 to 6.3 jack, USB cable and hexagonal driver
The new remote control was built by Aluminum, kind of heavy one.
The stock hexagonal driver is used to open up remote control
There is one button with power on/ function on front panel, and two LCD display, knob for volume control, 6.3mm single end headphone output, 4.4mm/XLR balanced headphone output.
Topping put DX9 block diagram on top cover with Acrylic
It looks nice when power on with orange LED, and it can be turned off if you want.
There is multiple display mode on two LCD display, including UV meter.
It’s really nice to have los of details on this 15th Anniv. DAC even those details would not get any improvement on SQ.
Full of IO ports on back panel including 2sets of XLR/RCA output (preamp and lineout), HDMI I2S input, 2sets of Cox/Opt, BT SMA jack, USB input, AES input and 12V trigger input/output.
Base plate, they used metal foot this time better than previously rubber foot.
Inside DX9, roughly say there is three block. Power on left, digital input/processing in the center and volume control with relay matrix on right side.
DX9 used 6sets new generation NCFA module for headphone amp, two set for single end and four for balanced.
There are three Meanwell A2D PSU, IRM-15-5 5V for digital power, 2*IRM-20-15 for analog power +/-15V.
It’ not usual to see three PSU on Topping DAC.
The reg of analog used TPS7A4901 and TPS7A3001, which provided +/- 14V as source, and the headphone amp use +/- 15V directly.
TPS7A4901/3001 are good but not the best, It’s pity that Topping didn’t use LT3045 but I understand that may be shortage risk since LT3094 was short the whole year.
D2D IC TPS65131 provide +7V as power source of DAC Vref. I didn’t trace the neg power.
BT module QCC5125 provided BT5.0 LDAC/aptX, kind of old chip.
USB transceiver used XMOS XU316. SPDIF transceiver used AK4118A, not sure what is the difference between AK4118A and AK4118.
DX9 still has Altera CPLD for digital process, but no external 45M/49M clock for re-clock this time.
Because it used AK4137EQ for SRC which build-in PLL, it’s my first time to see SRC chip in Topping DAC.
System control MCU used SYNWIT SWM34SVE16-50. The blue module is unknown one, probably used for FFT monitor I guess. Maybe someone can tell me what is that?
The keyman AK4499EQ surround by 4pcs of OPA1612 which used to provide Vref 4.75V.
It’s new design from datasheet cause AKM recommend to use 2200uF caps on Vref as LPF, but it can’t add big caps on Vref this time duo to OPA capacitor load capability.
The bottom side IC is ultra-low noise reg AK1118 which provided AVDD 5V. the next one Microne LDO provided 3.3V.
The top side 4pcs OPA1612 are I/V converter and those 4pcs Rubycon YXJ 220uF25V are coupling caps on signal. The right up OP is OPA1612 used to converter as single-end.
The volume control relay matrix, I am not sure how it works as hybrid but it reduce the numbers of relay and resister.
I can hear the relay sound every 6dB. The headphone amp input buffers are still OPA1612.
Topping new generation NCFA module, no shielding can and epoxy will be a good news.
The headphone MOS are nexperia PBSS305NZ/PBSS305PZ
DC detect used ST OPA 072C
The backside of PCB, there is less flux than before unless reworked connector. Which means that SMT process got improvement in Topping factory.
The DAC stack with D90MQA / D90SE and D90 III. Almost all the flagship DAC in Topping.
Test result, I used E1DA COSMOS ADC+RMAA as quick scan. Topping already provide a specific test report so no need to expend RMAA dashboard.
Let me know if you have question on this report, thank you.
Good job, thanks a lot for sharing the details.
Excellent work @whydan, thank you !
Just a tip: the crosstalk number suggests that perhaps you left the Cosmos in Mono Mode. The results should be twice as high for a DAC of this class.
Thanks for advice @VintageFlanker , I didn't realize mono / stereo mode before.
And yes, I did use mono mode after read from Ivan's website, the Windows volume is 100% or close to 100% if RMAA needed.
I would advise to use the Cosmos software to set either calibration, A/D filters, and Mono / Stereo (instead of Windows volume) :
Hello. Anyone used it as a bridge preamp on a multichannel system? I own an integra drx 8.4 and when playing movies etc I am planning to use its xlr pream outputs for FL/FR to feed the dx9 balanced inputs and from the topping outputs feed an audiophonics purify poweramp.
So basically the questions are:
1) is it truly balanced from input to output so that I will void signal degadation?
2) Do the dacs interfere in my case or is it purely analogies connection?
3) does it have a volume bypass or unity gain mode?
And how about it's headphone amp section? I will be using it with either focal clears pro (1st gen) or with neumanns ndh 30s
Thanks in advance.
Hmmmm... nope, my mistake. There are no analogue inputs in there. It's just a seperate set of pream outputs. Shame.
Hello,
I recently purchased one of these and am having a weird issue with the rear LED strip. The brightness does not adjust with the setting in the display menu. Whenever I switch the LED setting to "OFF", the rear LEDs stay on (see picture). Would anyone have any input on this? Does anyone know how the LEDs are connected? Maybe it is an issue with the firmware, but I did update the firmware and try a factory reset. I also sent an email to Topping but if it is something I can fix myself, I would rather do that.
Thank you.
Hello,
Thank you.
LED controlled by MCU with some MOS as I recalled, and a jump wire connect from PWR to LED light bar strip.
If you can't control the LED then there is some problem on MCU no matter FW or protential HW issue.
Probably you may need RMA since you can'y repair it by FW updtae, or you can wait further response from Topping Service.
Sorry to resurrect this thread. I'm new to audio electronics, trying to learn the best I can. I have a dream of making my own 8 chanel active crossover (4way stereo setup). So far I managed to build my own ADAU based DSP which is working fine. Currently using china PCM5102 DACs. Next step is to design the DAC section with a goal of making a 8 channel DAC based on AK4493SEQ. But for now Im just trying to get the hang of analog audio and all its secrets :P
I have a few questions regarding the power supply in this device as it seems exactly like what i need:
  1. I suspect the two IRM-20-15 are connected in "series" with the center point being signal GND for the rest of the PCB and thus creating a +/-15V supply right?
  2. I guess these inductors (110uH) are mounted in series (220uH) with one 470uH inductor forming a LC filter of around 500Hz, one for the positive rail and one for the negative rail.
    But what is the small ceramic capacitor and resistor between the 470uF and 100uF caps doing? Is it a RC filter? those resistors just doesn't look like they can hadle a lot of power (not that much is needed but..)?
    I guess the rest of the components around the TPS7A4901/3001 are just according to datasheet: input output, sense, set and so on.
    But what are those two small parts doing in between there?
  3. I suppose the positive/negative TPS65131 SMPS is powered from the 5V IRM module. But why would they implement this if they already have +/- 14V from the other two IRM modules? what is it powering?
Sorry for these vaque and probably stupid questions, but we all gotta start somewhere :D
Thanks!
Thanks!
Hello, glad to see you're working on your multi-channel project.
I returned DX9 to my friends so my answer relied on my memory.
1. yes, those two IRM20-15 series and the center point is GND for rest. It can be designed like that just because IRM20 is an isolated PSU.
2. I can't remember if those two chocks series for each power rail, but the answer should be yes regarding to my photos.
It have to set for the working frequency of IRM20 which can reduce high frequency noise from PSU.
I can't trace on that resistor and MLCC, and those two won't be RC filter since it can stand that high current.
Suspect that should be short start for TPS7A4901 on EN pin, RC make a delay then enable regulators.
3. Suspect TPS65131 should used to adjust Vref which will impact the output voltage level, since Topping DAC should have 4V/5V output mode.
I didn't have a full trace on all power rail so I am not sure which power rail used from TPS65131.
Best guess? Suspect it used for the blue module which is an DAC module to provide FFT display.
At last, those are good questions, any question is welcome.
Thanks for the feedback!
Yeah a delayed enable seems like the most likely use of those two components. Thanks!
