Welcome Aboard @nitinvaid20.when i remove the optical cable it wont show anything and when its inserted it is showing 48Khz means its working and detecting the connection.. but no sound
ThanksWelcome Aboard @nitinvaid20.
Was hoping someone would answer first since I don't have time to bring up the manual, but basically...I need to ask few things what is PO? when its showing
USB>PO
USB>P+L
and what does FIR do? PCM FIR 1 ,2 ....7
what is the meaning of all 3 options
I'm pretty sure there's a manual with answers to these questions.I need to ask few things what is PO? when its showing
USB>PO
USB>P+L
It is unbelievable that such a loss accident occurred at a shipping company like DHL.Update: my unit got lost in transit, fuck DHL
Hello,
Using this dac/amp with the Denon AH-D7200 for several weeks now, is the purchase of an amplifier necessary?
In low gain, I am between -35db and -55db
Impedance of my headphones : 25ohm
Sensitivity : 105 dB/mW
Thanks for your answer.
I don't know if it's worth getting a Topping A30pro or A90 since I've read some tests that recommend a headphone/IEM > 16ohm for the dx7 pro.
If you don't need a powerfull headphone amplifier the DX7Pro will be fine. Btw on Audiophonics The DX7Pro and the D70s are both priced 603.99 Euro.DX7Pro vs D70s ?!?
I'm trying to replace an older yet reliable Fiio E09K/E17 Combi together with Adam Audio A5X active near field monitors and a Sub 7 (2.1 setup)
I've been watching many reviews and reading a bunch about these products - and in mid 2019 I tried a DX3Pro, but was underwhelmed and sent it back. From what I can read, I suspect I'd be happier with the AKM based D70s - but open for suggestions / comments / feedback
I can now get either the D70s or Dx7Pro for same price of €649 - really unsure which to get and which has more bang for the buck ?!?! Really torn between the two . . .
Any feedback welcome - and Stay Safe!
As you can read in my review in this thread I'm very happy with the dx7pro. What puzzles me is that you tried the dx3pro before but were underwelmed. If there is an audible difference between dacs of the same brand it's most probably in the preamp part. I'm pretty sure I wouldn't be able to tell an akm from an ess dac. My best guess is that the preamp wasn't powerfull enough or that you don't like a dac/pre that doesn't impose a sound of its own.DX7Pro vs D70s ?!?
Both are top notch measured. Dx7Pro has (imo) better usability because of the headphone amp.Great !! Now I just need to know which one is best for that price
