I got it very happy with it to say the least!!Does your friend want to sell his DAC3? You can DM me.
Ok so I finally received my Dx7 Pro yesterday and today spent about an hour comparing it to Chord Qutest.
Is it a 'Chord Qutest killer'? For me it surely is. I hoped that it will sound no worse than Qutest, but in fact, I like its sound even more. It's a very small difference indeed, but its sound is a little bit more open without treble becoming harsher. Voices are just this ted bit more alive. Qutest is a very very good DAC, but to my (untrained) ears certainly no better than DX7 pro. Doesn't seem that there is any magic behind those 50,000 "taps" that Rob Watts is advertising.
Headphone amp also seems to work well. I was listening to some podcasts yesterday evening and compared how voices sound via 3,5mm jack on my iMac and via Topping DX7 Pro. Although iMac's headphone jack sounds good, it does add some irritating edges to words which are absent via Topping. Well recorded dialogues are much more pleasant to listen to via Topping DX7 Pro.
The packaging and design craftsmanship are also superb.
So overall I'm very happy with this purchase and thanks to ASR for this review once again.
@veeceemView attachment 38876
SE is 6ohm and so balanced is twice that: 12ohm. 4.4mm is wired to the balanced output, therefore 12ohm and in fact worse in this regard than the 1/4 output.Already tested or any chance to test the impedance for the 4.4mm balanced output?
I would expect it better than the 1/4 unbalanced output.
Alou, can't disagree with you there!
I do have a stereo system with a Rega integrated amp/turntable/phono stage and Dynaudio bookshelfs.
@MediumRare trying to output a digital signal to my DAC which worked without issues for the last year with the D50, DX7 Pro in the same system seems to be more sensitive to signal issues as I have short dropouts in audio no matter which cable or setting I try
But I also noticed that link I posted isn't actually correct, as I do have a standard 3.5mm audio out as well on my TV.
So.. I went full PICKLE RICK and connected a good 3.5mm->RCA to my amp, selected the Audio Out (Line Out) option and well, it works...
Assuming my goal is just stereo sound how "bad" is the 3.5mm output from a technical standpoint in my setup?
Another option would be an OPT->COAX converter and then using that for the DAC, but that's also a gamble at this point since the issue is clearly on the TV side.
Topping designed the DX7 series to slowly increase the volume when its sent a sudden signal, to avoid sound discomfort.
That's great info, super helpful for DX7 Pro owners. Do you have a link to where this feature is documented by Topping or one of the sellers?
Topping designed the DX7 series to slowly increase the volume when its sent a sudden signal, to avoid sound discomfort. The TV is basically adding some kind of noise that triggers this feature in DX7 models. This issue isn't present in the DX3 Pro. I really dislike this feature and it's a shame that Topping still puts it in its DX7 series. However, it's the TV's fault for having a crappy optical transport as well.
That's what I would expect if there are difference between very competent DAC's. It will be subtle. Most of the time we only pick up öbvious"differences if something is really broken or not properly level matched.
Great to hear that a reasonably priced DAC like the DX7Pro goes toe to to with something over 3x its MRSP and bests it in some areas even if its subjective.
We did a couple of more switchings between these DACs, but all HD and Ultra HD songs on Amazon that we listened had this luxury touch on Qutest that was not there with Topping.
So for now the Topping is relegated to become a replacement for the headphone jack on my iMac, while Qutest continues its duty in the main system.
@Veri @veeceem
A few days ago I posted my first impressions on Chord Qutest vs Topping DX7 Pro where I said that to me DX7 Pro in fact betters Chord Qutest.
Today I have done some more listening with my wife who is 18 years younger and still in her early 20s and after switching from Qutest to DX7 Pro she said that the sound from Topping lacks luxuriousness and lusciousness that she feels with Qutest. And as she said it I immediately realized that she was right. We did a couple of more switchings between these DACs, but all HD and Ultra HD songs on Amazon that we listened had this luxury touch on Qutest that was not there with Topping.
@Veri @veeceem
@Vovgan tbh, after buying Anthem STR preamp, use its DAC and its room correction feature (ARC). Qutest and DX7 Pro is now eating dust cant live without RC now I guess. Next purchase for my bed room setup will be NAD C658 or MiniDSP SHD or anything with RC biggest improvement ever since I started this hobby
Please tell me.
Does this symptom mean that the fade-in behavior works first when playing a song?
Please tell me.
Well now there’s no point for me to continue comparing the two because it would look like I’m trying to make my wife change her opinion and I see no potential benefit in trying to do it since frankly we’re now both of the same opinion. Should I change Qutest for Topping now, we will both regret it, so we’re done experimenting with DX7 Pro. It’s all 100% subjective of course, just felt that it would be right on my part to post my second and final impression here.
P.S. It was not a blind test and I still wouldn’t bet much (but some) that I can differentiate the two in a blind test.
