- Thread Starter
- #81
Yes.
I think it was $379 or something like that.
BTW, I have both the DX7s and D50 in house. THe D50 has had no announcements other than a picture on their site.
I see a volume control on the pic, or am I wrong?It is a pure DAC without headphone out, volume control, etc. It is much smaller. Topping told me it is NOT a replacement for D30. So not sure what its positioning is. It looks very solid and nice though.
I have not had a chance to power it up.
That was my mistake . I didn't see a rotary knob at first and assumed it didn't have one. But then looked again and saw the up/down arrows and display.I see a volume control on the pic, or am I wrong?
I never thought these chinese Dacs could measure this good, especially on Jitter..
What about that "proprietary antijitter" circuit that most big names Dacs mention in the specs, is that snake oil?
so, basically if I use a cheap transport with high jitter, like spidf out of a network player, these dacs would measure worse than in above tests?In many cases they are talking about a low-jitter clock source NOT what comes out of the DAC. The output of the DAC can get polluted by other means and create jitter of its own.
Also the ultra-low jitter clock sources reduce jitter at ultra low frequencies which are simply not an audible concern to effects of masking.
It does not. It is small brick and no room for XLR connectors. It has the same connectivity as D30.
Welcome to the forum. And no, it does not. The D50 is very thin, barely thicker than the RCA jacks so no room for balanced even if they wanted to put them in.Hey, Amirm, this is my first post in the forums. I'd just like to ask: does the Topping D50 have balanced outputs?
Thanks for the spec. Didn't know that was up.
The back of the unit is full already and this is a very small box. They made a design decision to make it this way with the DX7s being the bigger brother with balanced audio out, balanced digital in, etc.
I can try to mod mine and see what happens.
No, the datasheet warns that the amp will oscillate potentially in megahertz region, degrading audible response. It is also useful for output protection but DX-7 may have a separate means for that.Is it at all necessary for protection against a shorted output?
You know, depending on the headphone you have, it may be possible to reduce the output impedance of DX7/DX7s. It is just a series resistor before the headphone jack. It is there to guard against too much capacitance causing oscillation. I can try to mod mine and see what happens.
