Topping DX5II teardown
You mentioned a 'PC': which OS is it running? (Windows, Mac, Linux...).
If the PC is running Windows, the issue might stem from one of their 'flawed' updates—something that happens frequently...
You might want to try your DAC with a Mac or, better yet, a Linux-based PC to rule out that possibility.
Beyond that, I don't have any other suggestions to offer.
Furthermore, given Topping's obvious expertise—especially since they created the device itself—I doubt they made a poor decision regarding the unit.
Troubleshooting a device of 'this caliber' would cost more than buying a new one, considering the hourly rate of an experienced, qualified electronics technician—and, as I mentioned, doing so without any schematics, relying solely on the user manual.
I run Linux, so Windows issues are eliminated.
I bought the DX5 II from Shenzenaudio over Amazon. Here in Germany they have to comply with certain warranty regulations. By law they would have to at least offer a repair, but would also have to cover the shipping themselves. Because they operate from China, they said the shipping costs would be too high, so they took the decision to just refund and leave me with the brick. Topping themselves weren't directly involved.
That is what I wrote earlier: Topping made the right decision, and it is a very positive move on their part—commercially speaking—towards the customers they trust; that’s all there is to it.
@ICIETDIYEUR, this is a zener diode, correct?
Measuring it the normal direction, I get 0.712V, but measuring it the opposite direction, I get around 1.001V. Is this a faulty one?
There is another one like this on the board that measures 0.788V in the normal direction and 0L in the opposite direction, which is what I would expect from a zener diode.
my topping dx5 II died, after i opened it i saw dead power source - ATAZ AD30-B15, where can i buy it or compatible power source that i can use instead?
It seems that these are similar.
Mean Well IRM 30-15
Mornsun LD30-23B15R2
LZTEC IRM-30-15
Reactions: moo
Note that they've apparently done some work and installed a different "rack" (sockets) for the 6.3mm + 4.4mm balance. All photos are from this same thread. The very beginning (August 2, 2025) and the end (from April 20, 2026)
How works new revision? Did you try pentaconn 4.4 connection?
Is there any information on how volume control was implemented in the DX5 II? I'm particularly interested in DSD playback.
Thank you!
so, i used Mean Well IRM 30-15 and it fixed broken unit
btwn, i noticed faint ticking noise when switching between different outputs (from dac, not headphones), is this fine behaviour?
I got a Mean Well IRM as well. But it didn't fix it for me though.
I purchased this device and have been using it for about two months. I haven’t used the 4.4mm balanced output on the front panel; the standard 3.5mm jack suffices for now. Mostly, I listen to this DAC through speakers connected via XLR. I’m quite pleased with the cloud-based management system (https://home.toppingaudio.com/); since I bought the unit, I’ve already updated its firmware about three times. So far, I have no complaints whatsoever about this device.
