Topping DX5II Balanced DAC and Headphone Amp Review
Rate this DAC & HP Amp
    Votes: 17 3.2%
    Votes: 19 3.6%
    Votes: 54 10.1%
    Votes: 445 83.2%
They have been posting frequent firmware updates to their website and also available through Topping Home.
If you are on one of the last 2 versions you may be fine. But, Lots of bugs being fixed still, so would be a good idea, but not 100% critical unless you have issues.
Good to hear.
I believe it was downloaded with firmware a couple of updates ago but no issues at all.
Finally got to making some XLR cables for the best signal path and man does this unit bring in the music.
Very happy with this Topping unit and had to put the Fosi ZH3 DAC headphone amp to rest for the eventual bedroom DAC setup when the new house is built.
I have discovered some odd behaviour with the display being turned off. With auto-off, the first command only turns on the display but is not executed, whereas with manual off, the first command is executed along with the display turning on. I have informed Topping of this and they said it would be fixed, but said the auto-off behaviour is the proper one, which I find odd as it requires pressing mute twice to mute and the same also applies for standby, input and output. Anyway, we will have to see what we get with the next firmware.
Is the issue with the 4.4mm balanced output still common today? I can only get this DAC via an online reseller that ships directly from China and they cannot check the hardware revision but they did show me a photo of the serial number and it starts with 261156. I dont know if that has any bearing, seller says its the latest batch.
If it's the latest batch, then it's likely v0.16 or v0.17, which does have a different PCB board/whatever it is for the 4.4mm connector. The other thing about the 4.4mm thing is it wasn't universal, and there's several different reasons why it was happening -- from legitimate HW failure (no electronics company is immune from that happening) to user error (i.e. not seating the connector fully, as it was for me the first time I connected to the 4.4mm jack) to negligence (i.e. hot swapping while content is playing, which can potentially cause a short to occur no matter what device you use).
I personally haven't had an issue with the 4.4mm connector, and I have one of the first/second production units (HW v0.15).
Any objections or is the firmware updates really necessary?
Im using the FW V2.31 since its release and its rocksolid.
If you dont need the new introduced web/App feautres, then there is no need to update any further beyond V2.31.
Thanks, would you know if this is visible on the box anywhere? maybe Ill just stick to the 6.5mm unbalanced that the Sony MV1 has, since its an easy to drive pair, there should be mo sonic differnece between the 4.4mm balanced and 6.5mm unbalanced.
No, there's nothing on the box indicating the HW version. The only known way would be to connect the DAC, open Topping Tune on your computer, and open the settings window. The issue with that is Topping has removed the DX5 II from the Topping Tune compatibility list (I think they've been slowly phasing it out in favour of the newer Home app -- which is honestly better IMO), and it's inconsistent in terms of the software working (some people see the HW/FW/TT versions, others just see X's).
Honestly, if they're saying its the latest batch, it's not likely to be the OG HW version (0.15) -- especially if it's the more popular silver/black SKU.
... Except there might be some important bug fixes. That would be the reason to go beyond v2.31.
Topping have given a more detailed reasoning for the display off behaviour.
We would like to explain the reasoning behind this design.
When the screen has been off for an extended period, users may have forgotten their current input, output, or other settings. We considered that, in most cases, users would simply want to wake up the screen to check their current settings before deciding what to do next.
Therefore, we designed the first button press while the screen is off to wake up the display rather than immediately execute the corresponding function. This helps prevent accidental changes to settings when users cannot see the current configuration.
Of course, we also understand your point. For users who prefer to operate the device directly, having to press a button an extra time may feel counterintuitive and add unnecessary steps.
This design is a trade-off between preventing accidental operations and providing a more convenient user experience. We will forward your feedback to our product team for consideration in future improvements.
I think being able to mute with a single button press when there is unexpected high output is very important. Particularly due to stress induced rigidity of motion such as firmly grabbing the remote. Further, it might be user configurable whether the first command is executed or just used to check. Also, checking can be reduced to a single button with a non-central function such as home.
What operation would you prefer:
A: execution of all first commands,
B: no execution of any first commands,
C: user configured choice between A and B on the device,
D: execution of all first commands except one/some to check
or something else?
If C is not possible, but would have been your choice, what would you choose instead?
or something else?
TBH, I agree with Topping. I use the volume button to control output and switch between HP BAL or LO BAL. I don't want the DX5 II to switch outputs just because I want to check the display. This mirrors the behaviour of my PC, when I press a key on my keyboard (which sits a few inches in front of my DX5 II), I expect the PC to wake and not execute from arbitrary command. I guess that users operating the DX5 II in a different context may feel differently about this.
The PC is not active when you press a button to wake it up. This is different from the DX5 II being active with merely the display turned off. Also, the commands used on the DX5 II when in use may not be so arbitrary, e.g. muting.
One could just toggle single volume steps back and forth to check the display or use a non-executed button if it were to exist. On a keyboard, those are most for programs that are not text editors. Still, I think most people would still want media key commands executed first press with the screensaver active, display off or account locked. This is how my computer works.
Your assertion is false. My PC is often active and playing music through my DX5 II with both my PC and DX5 II screens blanked.
One could do many things, but I don't want to have to change the volume on my DX5 II to wake the screen.
Well, no one (0) liked your post and three people (3) liked my response to your post. So the available evidence suggests that 'most people' agree with me. Perhaps it's time to reflect and recalibrate your thoughts on the matter? :)
Your PC being awoken implies it was asleep, which is contradicted by it being active.
Why did you pick that segment to quote for your reply? Do you now want to discuss how computers should respond? The engineers at Apple that designed my computer have more to say about that than anybody here, fortunately.
I doubt the agreement pertains to your comparison, which adequacy I questioned, but is rather with your agreement with Topping's choice.
I think 'most people' would simply turn the volume down; I certainly would.
Some might still want to mute, when it is much louder than expected. I have not made any assertion there about what most people would want, so I have no idea why you would use quotes there.
1. A PC screen can be put into sleep mode without the whole PC going to sleep. I'm comparing the method of waking the screen on both devices and the implications of doing so. I appreciate I said 'wake the PC' in an earlier comment and did not explicitly mention the screen, but given the topic of the conversation is waking the screen of the DX5 II, why would one assume I was referring to waking the the whole PC rather than just it's screen?
2. I picked that segment because it included the phrase 'most people' and my response related to the relative number of people who had responded positively to both our posts i.e. challenging the use of 'most people'.
3. I used quotes around 'most people' because I was re-using a phrase in my assertion that you had used previously in your own and it seemed correct to do so. I apologise if this led to any confusion.
To, 1, because the screen was not mentioned as such and PCs being put or going into standby are common as well. Some people are really quite literal in their reading, also. The rest I am not going to bother bickering with.
Since the latest firmware update 2.58, I can no longer access its web interface. Is anyone else experiencing the same issue?
One more question: is there a way to assign DAC mode to a remote control shortcut?
Thanks, everyone!
Thanks, everyone!
- There's no reason why the Home web control centre would stop working. Platform? browser? did you disconnect the USB input?
- Not to my knowledge
Tried on chrome on latest MacOs
I'm on MacOS, and it works fine for me. I also only use Chrome as my web browser. Is the browser up to date?
