Hey lads! Just wanted to chime in with my experience of owning the Topping DX5 II so far.
My unit arrived in December of 2025 so it's running on the first hardware revision(v0.15).
I'm only using the Balanced XLR line outs for my active speakers and the single ended 6.35mm headphone jack. I don't currently own any headphones that are actually using/come with a 4.4mm balanced connection and honestly I have a huge amount of headroom even on my 470 ohm AT R70X... usually listening at -40db.
The only issue I have encountered with the unit was 3 or 4 months ago where I was getting repeated disconnects/reconnects once a week. Because the disconnect/reconnect sequence was so quick, it would actually slow down my whole computer. Initially I thought it was a Windows issue, but even after restarting the issue would persist, the only fix would be unplugging and re-plugging the DX5.
Thankfully the issue just disappeared after a firmware update, maybe after v2.14 as far as I remember.
My DX5 II is approaching 10 months of usage and outside of the small hiccup I mentioned above, everything worked flawlessly so far. I actually love the auto start/stand by feature. I already have to turn on/off both of my speakers manually and previously I had to turn on my Fiio K9 too... the DX5 removes that. Also, if we're making comparisons, the K9 was getting a LOT hotter than the DX5 + the K9 also had an intermittent issue where it just wouldn't start at all, unless unplugged for like 1 minute.
It's true that I did not use the 4.4mm headphone out and probably avoided most of the issues others have encountered. Still, I wanted to post something positive about this DAC/AMP as I see many people(or only the ones that bother posting on forums
) just having negative experiences with the DX5 II.
