Topping DX5II Balanced DAC and Headphone Amp Review
Rate this DAC & HP Amp
    Votes: 17 3.2%
    Votes: 19 3.6%
    Votes: 54 10.1%
    Votes: 445 83.2%
Frequent firmware updates should be a good sign, right? Or, is dx5ii just constantly having issues? E50ii seems to have some firmware issues. At least, I like Topping being quite responsive.
I would rather have too many updates than none at all. The DX5 II was one of Topping's first devices with a dependency on software (for PEQ, etc.), so I think greater number of firmware updates supporting new features, in addition to just bug fixes, should be expected.
I do not understand the complaining about getting FW updates (I'm not suggesting you are). Not only do they fix problems with the device, they introduce new features (some of which were suggested to them by people here), and I can't see how that's a bad thing.
The DX5 II is not constantly having issues, a few of the last handful of updates have actually added features. The last issue I personally encountered was the unit would factory reset itself if you chose the Jan Meier Cross Feed profile, but that was fixed several FWs ago. Haven't ran into any real issues since.
Check the hardware version (with Topping tune) . New 4.4mm board is installed since 0.16.
Depending on the FW installed, it may no longer be possible to check via Topping Tune, but outside of opening the device (as @Berwhale mentioned), that was the only way (AFAIK) to see the HW version.
With the latest versions of the DX5 II firmware (2.53) and Topping Tune (1.16) :
I can't view my firmware version or other details in the Topping app; it just shows "XX" next to each item. I don't know how to check the software and hardware versions.
Should be very easy
I can confirm, it started recently, after updating the firmware to 2.53
So strange that some people don't seem to have a problem (as per @Janfi67 's post above), and some do.
I have found an issue with FW2.53 and FW2.51. When streaming zeros to maintain USB connection between the DX5 II and macOS, there is occasional quite loud popping during sample rate changes (I tested 44.1 kHz to 96 kHz and back). When not streaming zeros, there are no loud pops during sample rate changes, but occasional loud pops when beginning to stream zeros again. It does not occur with FW2.46.
I have emailed Topping about this, but per their auto-reply they are on holiday from 25. September to 6. October, so this will be with us for a bit still.
I will test this when I get home.
Be careful with how much power goes to your speakers. I have mine turned down quite a bit and it is still a bit unsettling. Also, I don't know if it is DC.
Thanks for the heads-up, I will make sure to turn the volume way down before testing.
Hey lads! Just wanted to chime in with my experience of owning the Topping DX5 II so far.
My unit arrived in December of 2025 so it's running on the first hardware revision(v0.15).
I'm only using the Balanced XLR line outs for my active speakers and the single ended 6.35mm headphone jack. I don't currently own any headphones that are actually using/come with a 4.4mm balanced connection and honestly I have a huge amount of headroom even on my 470 ohm AT R70X... usually listening at -40db.
The only issue I have encountered with the unit was 3 or 4 months ago where I was getting repeated disconnects/reconnects once a week. Because the disconnect/reconnect sequence was so quick, it would actually slow down my whole computer. Initially I thought it was a Windows issue, but even after restarting the issue would persist, the only fix would be unplugging and re-plugging the power chord on the amp.
Thankfully the issue just disappeared after a firmware update, maybe after v2.14 as far as I remember.
My DX5 II is approaching 10 months of usage and outside of the small hiccup I mentioned above, everything worked flawlessly so far. I actually love the auto start/stand by feature. I already have to turn on/off both of my speakers manually and previously I had to turn on my Fiio K9 too... the DX5 removes that. Also, if we're making comparisons, the K9 was getting a LOT hotter than the DX5 + the K9 also had an intermittent issue where it just wouldn't start at all, unless unplugged for like 1 minute.
It's true that I did not use the 4.4mm headphone out and probably avoided most of the issues others have encountered. Still, I wanted to post something positive about this DAC/AMP as I see many people(or only the ones that bother posting on forums :)) just having negative experiences with the DX5 II.
