staticV3
- Joined
- Aug 29, 2019
- Messages
- 15,441
- Likes
- 27,297
What d'ya think?Soooo.... Is this actually true or a load of bollocks?![]()
the latter actually. Both are identical when it comes to sound, albeit the 6.35mm socket is less issue prone igFrom this review:
"The two balanced outputs from the dx 5, the 4.4mm and XLR sounds a little bit crisper and a little bit more detailed than the 6.3mm socket. The sound from the 6.3mm socket is not at all bad, but you can hear that the circuit has been optimized for the balanced outputs so that's the circuit I would use if you can."
Soooo.... Is this actually true or a load of bollocks?Using a 32 ohm headset (Empyrean) so it's already more than loud enough even on low gain so extra power from balanced won't matter I think....
From this review:
It simply provides more power and plays louder. After switching to balanced you might indeed think that the "quality" of the sound got "better" because suddenly your brain starts to focus on those dominating hard hitting instruments and vocals but in fact it only got louder...From this review:
check the USB cable, check the USB port on your computer, maybe the cable is looseIs my device bricked? Can I re-flash the firmware using tools?
Any help would be very appreciated!
Hey guys,
Lately, I have been having issues with the standby mode on the Topping DX5II. Sometimes I couldn't wake it up by using the remote, and it also refused to pick up USB signal from my PC. I had to flip the power switch off and on again to get it working.
Therefore, I tried updating the firmware to the latest version 2.14, hoping this could fix my issue. I followed exactly the instruction on Topping official website. However, the update process somehow failed and now it shows "No firmware".
I tried other cables and USB ports but nothing worked.check the USB cable, check the USB port on your computer, maybe the cable is loose
Now when I plug the DAC to my PC, it just prompts me to format the disk.
As it has been mentioned, check the USB cable, but did you unzip the folder you download from the site, and only drag the individual FW file over or did you inadvertently drag the whole folder over?
Also, I have had my own DX5 II not come out of standby mode before (it's been an issue since FW v1.93 for me). I have reported it to Topping, but because it happens so infrequently (maybe once every 2-3 weeks, if that), and there's no definitive steps to reproduce (yet), they haven't really done anything to resolve that problem.
I'm currently using the USB cable that comes with the DAC
I swear that I only copied the FW file over. Actually I've already update the FW several times before and have had no issues. The FW before my update attempt was 2.10.
Maybe my unit was defective. I've experienced a boot loop with Topping logo once before, but a FW update fixed it
Topping strikes again, as many products as topping sends Amir to be evaluated, they should have a presence on this forum like Luxsin.View attachment 531189
Hey guys,
Is the 12V trigger always on when the Topping is powered/out of standby? I want to trigger some speaker with the trigger signal, but only when I play sound out of them. They will be connected to the RCA ports, but I will also be using headphones, where the speakers should optimally be off. Currently it looks like the 12V signal is always on, meaning the speakers will also be turned on, even though I am playing through headphones.
It would be a really nice feature to be able to select when the trigger should be ON.
I dont own the Topping yet, thus why I am askingIf you have a 12v trigger cable, and a power amp with a 12v trigger input, you could easily test that out.
I dont own the Topping yet, thus why I am asking![]()
Thank you! If it is always on, which I suspect, it would be nice if Topping could implement this feature. Worst case, it is just a hardwired 12V buck that creates that 12V signal, in which case it can't be controlled.I can easily test that out this evening, and get back to you.
