ziggurcat
Going to FW 1.88 reset settings for me. Going from it to 1.91 did not.
Same.
If you happen to have a few moments to verify a possible issue (details are in the linked post in post #1115 above).
Since I know you have a SMSL PO100, you would be able to connect things in the exact same way I do. Basically, install the FW (which I think you already have), connect your Macbook to your DX5 II with the PO100 in between, select the OPT input on the DX5 II, press either of the C buttons on the remote (this is done because in my testing with the beta FWs, this effectively "resets" the issue, and ensures that it will trigger -- if you don't want to go through the trouble of redoing your settings, save the preset first before pressing the corresponding C button), and then listen to some music for about 10 minutes max (local files or something like Bandcamp online).
If you're "lucky", you'll hear a hiccup/stutter within the first minute, but sometimes it takes a bit longer. I just tested myself on v1.91, and it happened within 30 seconds -- listening with headphones will definitely help catch the hiccup/stutter To correct it, go into the settings, and flip the SPDIF modes back and forth (from 1 to 2, and back to 1, but wait for the relay click to happen after changing the setting each time, just in case).
