I have not seen that, and I will try it out. I did try the Qobuz trick that
@JIW discovered with the SMSL RAW MDA-1, but it didn't resolve the issue with my Topping DACs, unfortunately (though seeing
@JIW 's posts again, I may have missed an important step).
I am currently using a Topping D10s in between my Mac and DAC that does 100% eliminate the popping. I have a SMSL PO100 Pro that also does the trick, but I like the look/feel of the D10s instead. I will bring my Air M2 and the DX5 II to work to see if it happens in a completely different environment. I can even connect the DX5 II to a PC at work. If it doesn't happen in either of those scenarios, then I definitely need to figure out what to do at home to fix the problem. If you recall, this all came to light when I added the 3e A7 into my desktop system. One of those tests was connecting everything to my M2 Air (connection was Air >> USB >> DAC >> TRS >> 3e A7 amp >> passive speakers), but I ran the Air off of its battery, and the issue still happened (this was done to see if it was specifically my M1 Mini).
Additionally, when I was doing all of that testing, it was with a D50 III DAC, and there were two audible pops. With the DX5 II, there's only one pop, and it isn't
as audible (if either of those things are clues). Under the new Tahoe 26.1 OS, there's an additional delay prior to the pop happening (5 or so seconds instead of about 1 second).
One of the very first things I tried was the Qobuz trick because when I tried out a SMSL RAW MDA-1, simply booting the app did the trick with that device. However reading your post in the first link makes me think I might have missed an important step (i.e. setting the output device in the app -- with the RAW MDA-1 I don't think that was necessary). I will try it again when I get home later tonight, and check out the TASCAM Hi-Res Editor. I don't love the idea of having an app always running in the background like that, though. However, if it does stop the pop once I made sure I've done it correctly, that is something I can bring to Topping since it could be something they can probably tweak via FW.
