Damn that sucks. Are you going to get it replaced? I assume it’s under warranty.Mine died already
It was actually pretty decent up until then for reliability without any issues. Wasn't even during a firmware update or anything: just turned it off for the night and it didn't start up the next day.
I have not experienced that, nor have I ever heard of that issue.Greetings to all community members! I'm experiencing this issue on my dx5 ii (firmware 1.78, Topping Tune 1.9): when I increase the volume while listening through headphones, distortion appears in the right channel starting at about -25 dB. After that, reducing the volume doesn't resolve the issue. After rebooting the device, the distortion disappears, but when I increase the volume, the issue recurs. This issue occurs with both the parametric equalizer on and off. This has never happened before. Has anyone else encountered a similar problem?
For reference Bluetooth works completely fine. But I was curious if I could take advantage of USB to get low-latency audio for some musical apps I'm running.Has anyone successfully used the Topping DX5 II with an Android device via its USB connection? I don't expect this to be a valid use-case and I assume Topping only tested this with PCs and Macs.
I thought it might just work, but I get distorted audio and it sounds very much like buffer underruns. I'm seeing PCM 48kHz on the DAC, which seems standard for Android so I don't think the samplerate is the problem.
Perhaps I expressed myself incorrectly and these distortions could indeed be called hissing. I've already written a letter to Topping's support team, I hope they can explain what might be causing this issue.Is it distortion or a hiss?
I have been trying to figure out a hissing noise from the Right channel over the last week that seems to involve the PEQ feature (FW v1.78, TT v1.09). I think I might have the steps down, but it's all still very unclear whether what I'm doing is the actual trigger. In my case as well, disconnecting the DX5 II does correct the issue. This is done by either turning it off from the switch on the back or pressing the C1/C2 buttons on the remote (which causes the DX5 II to momentarily disconnect).
I have only had this happen with PEQ enabled, and it seems like it's partially caused by how I have my particular desktop system set up.
While listening to music on my headphones (Fiio FT1 PRO), I simply turned up the volume and heard this hissing noise in the right channel. I thought there was something wrong with my headphones, so I swapped them for a different pair, but the problem persisted. Furthermore, turning the equalizer on and off doesn't solve the problem; only turning the device off with the button on the back does.Are you able to list the steps you've done to get this to trigger?
And how are things connected?
I'm using the HPA BAL and a 4.4mm cable with FiiO FT1 PRO headphones. The issue doesn't resolve itself when I press the C1 or C2 buttons on the remote.I have not had it happen just by turning up the volume on the DX5 II. I'm using HPA BAL, and I'm using the 4.4mm cable with my FiiO FT1 headphones. If you get it to happen again, try pressing the C1 or C2 buttons on the DX5 II remote. I have noticed that the DX5 II will momentarily disconnect from my computer, which is enough to cause the hiss to stop in my experience.
How do you have the DX5 II connected (i.e. USB, OPT, COAX)? I have things connected rather uniquely in order to fix a popping issue from my Mac's USB output. So, for me I have USB out from my Mac to a Topping D10s, then TOSLINK out from that to the DX5 II. I also have a physical USB connection from the DX5 II to my Mac to be able to update FW, and add/edit/remove PEQ profiles in TT, but I only have the OPT input enabled in my DX5 II's Input Option menu (USB is disabled in the Input Option menu).
I have not been able to reproduce the hiss with only USB out from the Mac to DX5 II (and removing the D10s entirely). With how I have to have things connected, it has involved creating a new PEQ profile in TT under the User Config tab, editing that slightly, selecting an already-existing PEQ profile instead, and putting everything to sleep. My D10s and DX5 II will periodically come out of/go back into standby over a period of time, and that is when the hiss triggers. It doesn't happen the first time they wake up/go back into standby, either, and can take a few hours for it to start hissing.
Sorry, I'm just curious. Why do you want to replace it?Can the DX5II be used as Pre-Amp for my JBL 306 (or other Desktop-Monitors) - it should replace my RME ADI 2 FS
Probably in terms of performance they're comparable. RME has more features, though. In terms of longevity, probably not comparable. DX5 ii is a lot cheaper....is the Topping DX5II comparable to the RME ADI-@ DAC FS...???...
