ziggurcat
I just had this happen to me today
turned it on and it was on coax when I only have optical connected
I would think the unit should sense what is actually being used?
If you have the device set to auto-detect in the Input Option menu, then yes, switching to the first signal it detects is the expected behaviour. Because I have it set to Manual in the Input Option menu, I think the device should stay on the input I have chosen (i.e. OPT). When the USB connection has been severed (but still active in the settings), then it does not switch to USB. It only does so when there's a physical USB connection.
Topping did respond to my bug submission this time (they did not when I reported the issue on FW 1.57). They asked for a video with the USB disconnected, but I told them that that is not likely to show the problem. I sent them two: one connected, one disconnected. As expected, when the USB connection is severed, the device doesn't switch to USB because no USB signal was detected. The issue, I think, is with the device auto-detecting the first signal type it receives when coming out of standby mode despite the settings being on Manual. I do also have the On/Off Trigger set to Signal, and it's possible that there's a conflict between the Manual input option and Signal trigger. If Topping won't fix this (even though they inadvertently had in 1.62), then I may be in a spot where I'll need some kind of USB DDC with a 12v trigger out, and use that On/Off Trigger instead of Signal.
