Yes, both devices use the same dual ES9039Q2M chips
I had the D50 III paired with the L50, and the only audible difference I have found was that I don't have to turn the volume up as much with the DX5 II vs. the L50. So in terms of sonic qualities, you might hear a difference, but in all likelihood you could be very hard-pressed to hear any difference at all?
IMO, the one big advantage that the DX5 II has over the D50 III is in its PEQ implementation. On the D50 III, you cannot apply filters to the left and right channels independently. You can with the DX5 II, which is great if you're wanting to EQ a pair of speakers in your desktop system (or perhaps a very basic 2ch TV system). Cosmetically, there are a lot more bells + whistles with the display options, if any of that is important to you.
The cons for the DX5 II is it's not without its issues when it comes to its integration with Topping Tune (a few people are still experiencing issues with the profiles not saving), and the D50 III/A50 III stack would likely yield fewer problems in that regard.
TL;DR -- if you want a bit more functionality with the PEQ, and a fancier GUI, then get the DX5 II. If you don't give a damn about PEQ or a fancy GUI, get the D50 III for the D50 III/A50 III stack. I personally don't think you're going to hear any sonic difference between the two setups.
