ziggurcat
I am looking for a room correction solution. Roon has a MUSE Convolution feature, but since I play sources other than Roon from my Mac, it would be best if I could use room correction with a USB DAC, such as the Topping DX5II.
Besides Topping DX5II and Topping Tune, miniDSP Flex and Dirac Live are my other candidates, though the latter is considerably more expensive.
I don't know about the future, but right now, I don't plan on using a subwoofer. For now, I need only 2ch room correction (not 2.1 or 4ch).
Do you have any comments on the room correction performance for 2ch of these two candidates? Or any other options?
It all depends on how deep down the rabbit hole you want to go (btw, you don't need Dirac if you decide on the miniDSP Flex).
