Yup. I might buy again in the future, but I will wait a few months until most of the bugs are gone.Unlucky you.
Yeah. I think the same, because no one has reported the same problem. But still pretty dissapointed and I don't think I will order a new unit right away.I truly think you received a defective unit, and no amount of FW updates would have resolved the problem you've experienced.
Even if you ordered one now, you wont possibly receive it for 3 months if Shenzhenaudio's backlog is applicable to all retailers.
Just to clarify topping's own store is listing a month delay on new orders, so if you eventually want to get one again get it direct from Topping.
It seems to be about demand, as they stated as the initial batch was already sold outHi.
I find it surprising, even rather 'strange', that a company such as TOPPING takes more than 3 months to relaunch a series of DACs (here the DX5 II) while much smaller companies take much less time and with fewer resources.
Is there a 'special' reason for this?...
Has this new series undergone material modifications compared to the first version marketed 'hastily'?...
Some quick measurements with Shelly Plug S (1W resolution, I don't know about accuracy):Has anyone measured the power consumption of the DX5 II?
Specific in standby (with and without USB connection
Question: can you testSome quick measurements with Shelly Plug S (1W resolution, I don't know about accuracy):
powered off via remote: 1W
powered on, no sound, no USB connected: 5W
powered on, no sound, with USB connected: 5-6W
Like with SINAD, it's not always possible to tell the distortion and noise apart in THD+N vs frequency plots, so we have to go with the lenient noise threshold again.
There is no difference whether I use HP output or lineout (with this 1W resolution).Question: can you test
HP Amp on
HP Amp off (DAC out only)
Will the DX5 II go into standby when the USB is not connected for some time?Some quick measurements with Shelly Plug S (1W resolution, I don't know about accuracy):
I don't think so. Manual only mentions that to go to standby you need to use power button on remote, or long-press volume knob, or use 12V trigger. No mention of automatic standby.Will the DX5 II go into standby when the USB is not connected for some time?
5W is way towards much.
I misread the manual, I thought that "Signal" section was about 12V signal. DX5 II does go to standby if USB is not connected for 1 minute by default.Will the DX5 II go into standby when the USB is not connected for some time?
Yep, can't be 1W at stby by all means, I would be illegal in Europe.EDIT: Seems that my meter isn't accurate enough for this low power consumption. I'm getting conflicting results with standby being 1W or 4W.
I know the definition of Stand By can be a little flexible sometimes, but not inside Europe, Topping must check that.~1W seems to check out:
