Bow_Wazoo
- Joined
- Jan 3, 2021
- Messages
- 1,097
- Likes
- 1,033
If you have the DX5 Gen II then that is a different product than this thread is dedicated for. As this thread is for Generation 1.yep, thank you. I have Dx5 second revision. SO this works for me. Will try.
PS What website are using for importing headphones eqs?
https://github.com/jaakkopasanen/AutoEq/tree/master/resultsWhat website are using for importing headphones eqs?
Here's the updated IMD performance:People hi
Amirm: have you re-measured the TOPPING DX5 with the latest firmware (v1.42)?
Normally the 'IMD/ESS HUMP' has disappeared and so have the TOSLINK jitter 'worries'.
I think it could be interesting to superimpose the different measurement tables of the TOPPING DX5 with the very latest TOPPING DX5 II.
We could very clearly compare the distortion in the higher frequencies between these two devices among others and thus see if the evolution proposed by TOPPING only concerns the PEQ/display (yes, the 12V trigger too) but not to the detriment of the SQ...![]()
Agreed. Making claims without backing them up with data. Not sure who has an irrational agenda, lol:Hi staticV3.
What projects?
What is irrational?
I'm being objective in comparing the results of precise measurements as we usually do, right?
Restrict BW to human hearing and the slight rise above 5kHz will be gone completely.
I guess you misread the context in which @staticV3 was irritated by the post of @ICIETDIYEUR. To be honest, I am, too.Agreed. Making claims without backing them up with data. Not sure who has an irrational agenda, lol:
Now I understand precisely what your initial reply meant. I was not aware your focus was on 'technical accuracy' of that comment. But a good reader could easily see that the point of @staticV3 was not at "5kHz" or "completely gone". His main point was, the THD+N rise above a certain high frequency is (not only already low but also) beyond human hearing and hence not a concern, nor a reason why @ICIETDIYEUR should rate the device below the other. I am pretty sure in his quick write-up his focus was not on its technical accuracy.@jkim Thanks for the background introduction. However that doesn't change where I stand. Limiting the testing bandwidth to 20KHz with a brick wall filter will not remove 2nd or 3rd harmonics of test signals between 5KHz and 6.67kHz, or 2nd harmonic of frequencies between 6.67kHz and 10kHz. So what is @staticV3's definition of 'gone completely'?
You could argue that 'Restrict BW to human hearing' does not necessarily mean a 20KHz brick wall filter, but rather a sharp cutoff filter following someone's hearing limit, or even an A-weighted result. We sure could use some clarifications there.
I definitely see your reasoning behind this. But don't you realize that your argument also in part relies on assumptions (without showing data)? First, a rise of wideband THD+N measurements between 5k - 10kHz could be substantially affected by tall order (> 3rd order) harmonics excited above 20 kHz---we do occasionally see considerable tall-order harmonics from devices. Second, in theory, fundamental tones above a certain high frequency can increase the noise level of a substantial frequency range---although I doubt this happens with 5k - 20kHz tones, some devices behave in such a way that certain frequency tones interfere with noise shaping.Due to oversampling and high order of and noise shaping, the quantization noise starts to show up in the noise floor way above 2x even 4x the sample rate. Even if the measurement BW is wide enough such that the quantization noise affects THD+N readings, its impact is equal for all test frequencies. By limiting the measurement BW, the noise component is reduced, but the harmonics of test signals <10kHz are not. The result would be a more prominent THD+N uptick in those test frequencies, if you can see it already in the high BW measurement (meaning at >5kHz, THD is already dominant in THD+N). That contradict with staticV3's claim of 'gone completely'.
This is a fair point. But at the same time we want to be careful in making a statement of this kind. This is not a simple issue we can discuss in one short sentence. At an extreme, as you know, we must stay humble because everyone's experience is its own and cannot be explained by theory and measurements, which challenges the main agenda of this Audio Science Review forum.Lastly, if you can't (or don't think you can) tell the audible difference between two units, just say so and no more. Please don't extend that conclusion to all humans. There may be someone out there in this planet that can reliably tell the difference when you and I cannot. I'd rather stay humble and curious.
Someone should do the math but both DACs should be tons cleaner than the speakers. Or any music played backIt is very clear that the DX5 II reproduces frequencies beyond 5kHz with more distortion (with an additional roll-off applied to reduce this effect) than the previous model (DX5).
I guess I don't belong to the 'good reader' then. The "5kHz" is very specific, and "completely gone" means absolute. There is really not much else in there for me to look the other way, no matter how you spin it. And I can't help but wonder, why are you working so hard to clean after him, why wouldn't he come back here and defend himself?Now I understand precisely what your initial reply meant. I was not aware your focus was on 'technical accuracy' of that comment. But a good reader could easily see that the point of @staticV3 was not at "5kHz" or "completely gone". His main point was, the THD+N rise above a certain high frequency is (not only already low but also) beyond human hearing and hence not a concern, nor a reason why @ICIETDIYEUR should rate the device below the other. I am pretty sure in his quick write-up his focus was not on its technical accuracy.
I gave you a generic analysis, you respond with uncommon situations. Do you have data showing the DX5 has any of the behaviors you listed here?I definitely see your reasoning behind this. But don't you realize that your argument also in part relies on assumptions (without showing data)? First, a rise of wideband THD+N measurements between 5k - 10kHz could be substantially affected by tall order (> 3rd order) harmonics excited above 20 kHz---we do occasionally see considerable tall-order harmonics from devices. Second, in theory, fundamental tones above a certain high frequency can increase the noise level of a substantial frequency range---although I doubt this happens with 5k - 20kHz tones, some devices behave in such a way that certain frequency tones interfere with noise shaping.
Not at all. The harmonics don't even have to be higher-order than 3rd, if you want to relax a bit your criticism of @staticV3's cursory comment. Most modern DACs' balanced output exhibits slightly greater (or at least as strong) 3rd-order harmonics than 2nd-order ones (due to CMRR cancellation of even-order harmonics). As you know, 3rd-order harmonics are beyond human hearing when fundamentals are above 6.7 kHz. Actually, below is what he meant (and I meant):I gave you a generic analysis, you respond with uncommon situations.
I don't have a close relationship with @staticV3, nor any particular reason to advocate him---I never exchanged an extensive communication with him. He is just a major contributor to ASR we often see (in fact, Grand ContributorI have no position in the dispute between your friend and the other member, but outright accusing someone having an 'irrational agenda' seems out of the line to me, not to mention based on some technical claim that has a weak ground.
What do you mean by 'Not at all'? You used two uncommon situations as counterexamples to my point ('First' and 'Second' below), but neither is reflected in the charts you re-posted. If you want to prove your point, at least come up with some data, if it is not already available somewhere on the internet.Not at all. The harmonics don't even have to be higher-order than 3rd, if you want to relax a bit your criticism of @staticV3's cursory comment. Most modern DACs' balanced output exhibits slightly greater (or at least as strong) 3rd-order harmonics than 2nd-order ones (due to CMRR cancellation of even-order harmonics). As you know, 3rd-order harmonics are beyond human hearing when fundamentals are above 6.7 kHz. Actually, below is what he meant (and I meant):
Why would I relax my criticism? Even you admit that '5 kHz' is inaccurate and 'completely gone' is hyperbole. Those essentially make the claim false, simple as that.With good filters (commonly chosen by most reviewers and users) and in BW 90kHz, THD+N is beginning to rise from 5k - 7kHz and elevated onwards. In BW 20kHz, however, THD+N in that range drops abruptly because the 3rd order harmonics, big contributors to BW90k THD+N, are excluded when the fundamental reaches 6.7 kHz. Sure, if you choose to, you may still want to be nitpicking about the '5 kHz' (for inaccuracy) or the 'completely gone' (for hyperbole) part in his communication. Of course, I did understand when you said that in BW 20kHz the THD would rather stand out above lower noise because the slightly rising BW90k THD+N is a sign of rising THD. But that is simply because noise is no longer the dominating factor in BW 20k THD+N.
Every time a new product came out, a seemingly thorough but same-o-same-o suite of measurement were done and then the conclusion was made that the distortion is vanishingly low and the sound this product produces should be indistinguishable from another. Yet some people tell you they sound different.And more critically, all this discussion is a moot point when considering any good headphones & speakers' THD levels should be at least 30 dBs higher and mask the THD of these modern electronics'. Actually, I don't see a problem objectively denying that "someone out there in this planet can reliably tell the difference," until I see the results of controlled experiments demonstrating this level of THD differences of modern DACs can be distinguishable.
