wemist01
Any idea why a "Fanmusic" version of this is only $314 at Amazon? I ordered one but am wary that it could be a knockoff.
Maybe a returned unit?Any idea why a "Fanmusic" version of this is only $314 at Amazon? I ordered one but am wary that it could be a knockoff.
This DAC is a balanced DAC, so when you use the balanced out connections on the DAC then you'll get the benefit of eliminating the ground loops - as far as I know it won't depend on what you connect it to, but your Kali IN-8 v2 monitors will be fine connecting it. Actually, I think whatever you're connecting it to needs to have balanced inputs, as the signal is up to 4V for a start - but surely your Kali IN-8 v2 monitors have balanced inputs?Out of curiosity (coming from someone with a lack of electrical engineering experience), would the XLR outputs on a device like this still work to eliminate ground hum when driving studio monitors, or do you lose that particular benefit of the professional-style connections when a device isn't balanced internally? I just got in a pair of Kali IN-8 v2 monitors that I'm running into a ground loop problem with on my current Element III, and I'm looking into solutions for eliminating it.
Thank you for the quick response. I wasn't sure whether the XLR outputs being driven by the SE topology had any impact on the functionality beyond outputting less power (which is always a non-issue for me given the low volume levels I listen at). Good to know this would be a viable option if my other attempts to break the ground loop fail.This DAC is a balanced DAC, so when you use the balanced out connections on the DAC then you'll get the benefit of eliminating the ground loops - as far as I know it won't depend on what you connect it to, but your Kali IN-8 v2 monitors will be fine connecting it.
Balanced (or differential, not sure about the fine points here) connections should eliminate any ground loops in your setup. Relatively few balanced devices are balanced internally, while nonetheless still providing that benefit. @amirm has said that’s the main reason to use balanced connections between devices. Common mode noise/interference rejection is the name of the game here. An actual electrical engineer could tell you more, and there will usually one or two lurking around these parts.Out of curiosity (coming from someone with a lack of electrical engineering experience), would the XLR outputs on a device like this still work to eliminate ground hum when driving studio monitors, or do you lose that particular benefit of the professional-style connections when a device isn't balanced internally? I just got in a pair of Kali IN-8 v2 monitors that I'm running into a ground loop problem with on my current Element III, and I'm looking into solutions for eliminating it.
... it outputs 4 volts. It's balanced.… except… is the DX5 truly a balanced DAC? Nowhere in Topping’s description does it explicitly say so, and if you look at the specs its “balanced” specs are exactly the same as SE…
Yep…you’re correct. I wonder why Topping doesn’t specifically say so, and while it offers a RV “balanced” output at the rear, it doesn’t offer a balanced HP output(?)... it outputs 4 volts. It's balanced.
Their website clearly says that the XLR Line out is balanced and that both the 1/4" and 4pin XLR headphone outs are single-ended:Yep…you’re correct. I wonder why Topping doesn’t specifically say so
As for why they do that, it's because contrary to balanced line out, balanced headphone out offers no advantage if the Amp is mains-powered.
And so Topping give their customers a 4pin XLR connector in case they already have such a cable or they like the rigidity, but they don't waste the resources to implement a differential headphone Amp.
Not sure I understand the question.why for this amp does the mains affect the hp output and not the line out?
Differential headphone Amps have value if you're working with power supply voltage constraints, like with USB or battery-powered equipment.
Since the DX5 is mains-powered, this does not apply.
Differential Line output has value in that it reduces EMI for long cable runs and suppresses common-mode noise from ground loops.
Those two points aren't related.
Hi, sorry I'm a newbie, what does this mean? That with my Slate VSX headphones - Impedance: 37 Ohm - the amp won't work well? So do you recommend other models from Topping?Testing at various impedances we get:
Ignore the little glitches (measurement error). At 300 and 600 ohm there is no clipping so if you are hearing distortion it is your headphone! Below that naturally is current limiting. Unit is stable and capable of driving even 12 ohm load. Output impedance is essentially zero.
www.audiosciencereview.com
Many thanks, I bought the productYour headphones will work fine with a DX5, and there is also the cheaper option of the DX5 Lite without the 'MQA tax'...
TOPPING DX5 Lite! Coming soon!
Better price till 25thMany thanks, I bought the product![]()
shenzhenaudio.com
